Question about Panasonic SC-HC3 Mini Stereo Audio System with iPod Dock SC-HC3 Shelf System
I tried turning my stereo on and when I press the power button all i hear is a click and nothing appears on the screen. It was working fine a few days ago and I just got this for Christmas
Have the same problem, email if you have a solution phill.wilkinson@ntlworld.com
Posted on Jan 02, 2011
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
Iphone will not turn on, if I connect it to my computer it makes a noise but nothing happens on the screen, I have tried holding down the on/off and the home buttons.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 12, 2010 | Apple iPhone Smartphone
IPhone won't charge - stuck in screen with battery and bolt
i have the same problem with my iphone 3gs 32gb have you found something that has worked? ive tried everything let me know if u find a way!! please!
Dec 29, 2009 | Apple iPhone Smartphone
The display is not appearing. I can hear it come
The Garmin fitness models are unreliable. Problems like this are common. The Motion Based forum will provide help. If a hard reset does not work you'll have to phone Garmin. I found this post regarding the Hard Reset:
"With the unit powered off hold down mode, continue to hold down mode while pressing power. Then let go of both buttons. You will be asked "Do you really want to erase all user data?" Select yes
If that doesn't work there is another "unprompted" hard reset that will clear all data immediately without asking. It's not easy to do, so you might have to try it several times before it works.
Hold down enter and mode while pressing power (don't hold down the power button, just press it quickly) Keep holding down enter and mode for a few more seconds. You will then see the "select language" screen and the rest of the initial setup screens."
Nov 04, 2009 | Garmin Forerunner 305 GPS Receiver
When I press the power button to turn the computer on, nothing is displayed on the LCD screen. Power light, Hard Drive light, and Battery Light all appear normally. I hear the fan blowing internally and...
Check the resolution of the screen by right clicking on an empty part of the screen and choosing properties. Go to settings and make the resolution 1078 x 768 and hit apply and ok. There are instances when the resolution will change from a software update etc. that is not supported by the monitor or graphics card.
Sep 03, 2009 | Dell Inspiron 1525 Laptop
When I turn my PS3 on, my background screen appears but nothing else loads, not even the numerous areas (Settings, network etc.) all that appears is an icon in the upper right hand corner saying "Press the...
you can try doing this cuz i had the same problem till i did this...Access the PS3 recovery menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Only white light appears nothing else appears.
hi
first try to connect to a pc using the usb and check if u can get connected and browseif this works then there is a problem with the display else the OS of the phone is lost
beware that all your data will be lost on the phone if the following procedure is followed
hold the green button '3' button and the '*' button simultaniously and then power on the device hold the keys till 'FORMATTING' is displayed on the screen
hope this helps
Cheers
Jun 17, 2009 | Nokia 3230
Acer aspire blue screen appeared went off now laptop starts up for few seconds then turns off again, but always a black screen hear the fan a few seconds but nothing
Try this:
  • check to make sure the fan is actually spinning and that there is no debri (dust bunnies) causing it to overheat.
  • Make sure there is nothing preventing airflow, you may need to tilt the back up to allow more airflow
Is there any display at all? Do you see a BIOS splash screen? Do you hear a beep shortly after powering on?
--if you have a splash screen, go into BIOS setup by pressing a button (del,F1,F10...whatever) then set it factory defaults and save changes
--also try removing anything that's detachable (USB, cards, dvd-rom, RAM, Battery...) Hold down the power button for 20 secs then plug in only the A/C and see if you get a bios screen
Hope this helps
Jun 10, 2009 | Acer Aspire 5100 Notebook
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Panasonic SC-HC3 Mini Stereo Audio System with iPod Dock SC-HC3 Shelf System Logo
389 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
