Where and what is the PBC button on the wireless linksys router?
Where will I find WPS button on my I pad touch
Posted on Jul 05, 2013
  • 33 Answers
Push Button Configuration (PBC)
NOTE: The PBC method is to be used if the wireless client device (device that you are using to connect to the network) has a WPS button (either an actual one or a virtual one).
Step 1:
Click or press the WPS button on the client device.
Step 2:
Click the WPS button on the Linksys device. A pop-up window from the Wireless > Basic Wireless Security tab of the Linksys device will appear. This window will indicate the progress of WPS client configuration.
Posted on Jan 01, 2011
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
Tip
Wireless Network Password - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
First
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Second
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
Where is wps on Belkin n1 vision?
Before you will be able to use this function, you will have to log into your router and enable WPS push button in the security settings.
PBC: Push and hold the WPS button located on the back of your N1
Vision for three seconds. Then, initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WP
Aug 21, 2013 | Linksys WRT160N Wireless Router
Cant find pin number on my linksys wireless router
To reset the Linksys back to the default settings -Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 06, 2012 | Linksys Wireless-G WRT54G Router
What's your problem?my ipod is asking for password to connect to wi-fi, what is my password? How do I find out what my password is?
Go to the Belkin setup page (http://192.168.2.1/index.asp) and select Wireless 1) Wi-Fi Protected Setup(WPS)
Select
2) Push Button Configuration (PBC) Method Push and hold PBC button on your Router for 3 seconds or click "Start PBC". Then start PBC on the device you want to connect to the Router within 2 minutes.
Oct 01, 2011 | Belkin Basic Wireless Router
Forget my password
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
http://192.168.1.1
You can protect your router by changing the default PW (write it down and putit in a safe place)
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 18, 2011 | Linksys Wireless-G WRT54G Router
What is the PBC button ?
The PBC button is used to automatically configure a connection. If you have a router that supports it and a wireless adapter, then you just have to push the button on the router, then the button on the adapter, they will create a secure connection between the two and you have a working, secure wireless connection.
Nov 29, 2010 | Samsung WIS09ABGN (8808993304486)...
What is the pbc button
installed on friends computer with bt router and connection request to press pbc button
Aug 17, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
Computers & Internet Logo
4,084 people viewed this question
David Payne
David Payne
