Question about Linksys WRE54G-RM 802.11g/b Wireless Adapter
My friend has a linksys router. (Not sure on the model). But I am trying to set up a WRE54G-RM range extender. I am able to go the setup, but then when I get to the point where I have to change some of the settings so it can connect to the network, I keep getting the following error: WRE54G cannot associate with this AP in repeater mode. After the error message, I go through the setup process all over again. How do I get past this??
  • bldragon41 Dec 31, 2010
    Thanx!
  • bldragon41 Jan 03, 2011
    I am trying to access the router config page. But when I type in 192.168.1.1, I cannot access it. It will not load. Do you have any suggestions as to how I can access it so I can get this done??
  • 536 Answers
Is the router set to allow extension of the network?
Is there MAC address filtering set up on the router?
Are you certain that you are connecting to the correct router? To be sure, change the SSID to something unique and not the default of "linksys".
Let us know how it goes and feel free to ask additional questions.
Thanks for using FixYa and Happy New Year!
Posted on Dec 31, 2010
  • 7 more comments
    To be honest, I am not sure about the questions you asked. The next time that I at their place, I will be sure to look. Thanx! Oh, I am connecting to the correct network, cause when I set it up, I changed the network name.
    Thanx again!!
    Happy New Year!
  • Jeffrey Groves
    Jeffrey Groves Dec 31, 2010
    It sounds like you know what you're doing and I have every confidence that you'll get it to work.
    Have fun!
    I am trying to access the router config page. But when I type in 192.168.1.1, it doesn't load the page at all. How can I access this page so I can check on the config of the router???????
  • Jeffrey Groves
    Jeffrey Groves Jan 03, 2011
    If you are using Windows, start a CMD (command prompt window) and type in:
    ipconfig /all
    From the output, you will see an entry for "Default Gateway". The associated IP address will be the IP address that you need to use to connect to the router's web config page.
    The default gateway is still 192.168.1.1. But I still cannot access the router config page. Do I need to reset the router and re-config the router??
  • Jeffrey Groves
    Jeffrey Groves Jan 04, 2011
    Yeah, it kind of sounds like the router has hung and needs a restart or possibly a reset.
  • bldragon41 Jan 04, 2011
    So, I should be able to just unplug it for a little bit then plug it back in and hopefully it will work, right?? If that doesn't work, do a complete reset?
  • bldragon41 Jan 07, 2011
    Ok, I was finally able to access the router config page, but where do I go to see if the network can be expanded, etc???
  • Jeffrey Groves
    Jeffrey Groves Jan 07, 2011
    dragon: I'm thinking that the same reason you were unable to access the router is the reason why the range extender did not work. Now that you have the router sorted-out, try setting-up the range extender. My bet is that it will work now. Let us know!
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
Feb 13, 2011 | Linksys WRT320N Wireless Kit
Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
The range expander helps to extend the range of wireless network...
Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
Site survey searches for the available wireless networks in range...
It should show your existing wireless network...
You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
Thats it...
You are done...
Your wireless network range would have extended now....
Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
I have a clearwire modem. I have to locate it 80 ft from my two home desktops and laptop. i need to know how to best do this. i have an e2000 router that i was hoping to use a wre54g range extender...
The Linksys E2000 router is N series router and the WRE54G is G range expander.
WRE54G is only computer with the WRT54G and WRT54GS routers.
You have E2000 router. I believe that router is capable of broadcasting the wireless signal upto 100 fts.
As Linksys says that router is capable of signal up 200 - 300 fts, but it is not.
You can try changing the wireless channel on the router to increase the signal.
Open the setup page of the router.
Go to wireless tab and change the configuration view to manual.
Try changing the channel to 11, 9, 6 ,1. See if that works.
Click Here for more information about the routers and network
Oct 02, 2010 | Linksys Computers & Internet
I purchased a wre54g range expander and have tried everything but it doesnt work
Who is the manufacturer of your wireless router?
check the IP address of your router.
connect the computer to the router and check the Ip address of the computer and the default gateway number. Default gateway is the IP address of your router. suppose the default gateway is 192.168.1.1. then open the set up page of the router . check the wireless settings of the router SSID ,channel and the security settings. Do not change the settings on the router.
If you are using WPA2 security settings them that will network on the WRE54G.
Now your range expander and the router IP addresses should be in the same range. Suppose you router IP address is 192.168.x.y and the IP address of the WRE54G is by default 192.168.1.240.
Now the x in the router IP address should be 1.
If it is, then connect the WRE to the router and open the set up page of WRE. change the wireless settigns on the WRE and power cycle the WRE and the router.
It should work
For more info about networking Click Here
Oct 06, 2009 | Linksys : WRE54G Wireless Range Extender...
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
Connecting 2 wireless routers
As a wi-fi technician, it is not recommended to extend the wireless signal using another wireless router. Having 2 wireless routers will just cause conflict to your wireless network. If you still have time, please replace the router with a Wireless Access Point (WAP54G). WAP is easy to setup. Just plug it to one of the ethernet port on the back of your router and run the setup CD that came with it, that's it. It'll extend your signal.
If your main concern is just extending your wireless signal to another far place outside your house, Wireless Range Expander (WRE54G) can also be used. It is a similar device like an Access Point but its signal extending capability is more powerful than Access Point. Its also easy to setup, just the setup CD that came with it.
You can also contact the Linksys toll free tech support # at 1800-3267114 if you wanna resolve the issue over the phone. Hope that helps.
-Regards
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Use Belkin f5d7230-4 as a wireless access point
Hi Druid,
Based upon what I've read regarding and experience with the F5D7230-4 is it will only work with another F5D7230-4 or F5D7231-4, F5D7130, F5D7132 and this are all Belkin products as well I thiink it has something to do with the WDS compliance for this specific model that's why they have clearly specified on the User Guide which devices are guaranteed to work with an F5D7230-4 that is set to AP Mode(Bridge/Repeater).
If you really want to exend the wireless coverage of your Linksys router I suggest you try the Wireless G Range expander(WRE54G v2.0/3.0 version 1.0 I do not recommend since it's somewhat challenging to configure since it has no ethernet port all the setup will be done wirelessly)
click this link for the User Guide of your Belkin router.
Aug 17, 2008 | Belkin (F5D7230-4) Router (587009)
WRT54GS V6
leave the wireless router settings unsecured then place the range expander as near as possible to the router. press autoconfig buttons and observe the lights...
Jan 12, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Range Expander...
Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
3. Power up the LinkSys Expander;
4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
5. Power off;
6. Move the Expander to your intended place of installation;
7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
8. Move your daughter's laptop to its intended location and try the system.
Should you still need a User's Guide, it is available here.
Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
Linksys WRE54G-RM 802.11g/b Wireless Adapter Logo
154 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
