Question about Cerwin Vega CLSC-15S Subwoofer
Cerwin vega at60 and dc1515
Hello
i am Damien from Belgium(English is not so good)and i had a pair of cerwin vega at60 speakers (20years old) but i blow up the woofers(the orange material around is broke.now i bought a pair of dc1515 secondhand and my question is if there is a product that we can put around the woofer(oil or something)so that in a copple of years i wont have the same problem again.(i dont now how to explaine the dammage but the orange/pink rubber around the woofer is broke of the age i think)
Regards
    Problem Solver:
  • 14 Answers
The problem is that the foam is affected by the ozone in the pollution we breath, it causes the foam to break down. It is less likely to happen with newer speakers since a minor change in formulation was made to prevent this from happening.
Solutions to your problem, there are two. First there are foam replacement kits that you can get. You remove the old foam and glue on a new replacement. The issue here is that there could be unseen damage to the voice coil, so it could be a short term replacement.
Second option is to replace the speakers, finding the exact Cerwin Vega replacement would be hard at best since the specific driver hasn't been made on 20 years. So you are left with finding a good replacement, that is where I come in, I have a universal 12" driver patterned after the Cerwin Vega woofer, so you will be able to retain the look of the speaker. Better though is that the speaker I have is a much better performer than the standard CV 12" woofer, and it will work in a 4 or 8 ohm system. You can read more about the product at http://www.mavin.com
Now the only true drawback you have is that being over seas, postage is going to drive up the price, and also you should always replace your drivers in pairs, so buy two. Given the age of your speakers if one is still working, it will go bad shortlyt due to the break down of the foam. Further when you change speakers in stereo pairs, both speakers should still sound the same since they contain the same components.
John
Posted on Aug 20, 2008
    President:
  • 624 Answers
It is called "dry-rot" and it happens with age to paper cone speakers. I am not aware of any products made to help prevent this problem. But you can always replace the woofers with new one's or find a place that "recones" speakers and that would solve your problem for a long time. If you have rubber surround on the cones, it would take much longer to have any type of dry-rot problems. The "foam" type of surround on the cones is the worst for this problem. Most new woofers have polypropelyne surround of the cones and it would probably outlast you, so replacement with a good quality woofer really is a good option.
Posted on Jul 08, 2008
Can i replace the 15" woofer with diecast aluminum
Yes. Contact CV for a replacement. Alternately, if you have a speaker refurbisher in your area, you can have them rebuild the one you have. There are only a few refurbishers/rebuilders in the US, so good luck.
Aug 04, 2011 | Cerwin Vega V-152 Main / Stereo Speaker
Will the E-715 work at 4 ohms
They will work at 4 ohm, but you won't get near as much volume out of them as you would if you used an 8 ohm amp. The E-715 speakers are rated for 8ohms. You could damage your amp running speakers that are not matched to the same ohm rating, however it is safer to run a low ohm amp to higher ohm speakers then it is to go from low ohm speakers to a high ohm amp. Your speakers will perform how they were intended if you match the ohm rating, so try to do that at if at all possible.
Chris
Jul 16, 2011 | Cerwin Vega Cerwin-Vega E-715 Floor...
Replacement (upgrade) tweeters
go to a radio shack if not in stock ..than order one...i would suggest a piezo style ...about 8 bucks each...
Apr 22, 2011 | Cerwin Vega Cerwin-Vega V-12F Floor...
I have a pair of Cerwin Vega LS 15-series home speakers. One of the subs stopped working but still has sound coming out of the voice coil. Do i need to replace the sub?
You need to check the connections on the cross over board and also Ohm out the speaker to see if the voice coil is open. If you cannot get the same woofer, then you should replace them in pair, try http://www.parts-express.com//index.cfm?
Feb 25, 2011 | Cerwin Vega LS-15 Speaker
Need to diagnose HF fault how do you open these up?
cabinets are built sealed from the factory, tamper proof
May 12, 2010 | Cerwin Vega Cerwin-Vega CLSC-10 3-Way...
Left Channel Woofer not working. I suspect the
I suspect a "blown" woofer! What does the dealer have to say?
Apr 20, 2010 | Cerwin Vega LS-10 Main / Stereo Speaker
Cerwin Vega CLSC-15S Subwoofer Logo
1,313 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
