Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
My ASUS Eee PC 1005HA turned off by itself then when I turn it on again, a screen come up and said "press F2 or tab" but when i press each of them, nothing's happened. How can I fix that?
Hi I have almost the same problem as ame_91_ok with my Asus Eee Pc 1005Ha. It suddenly shut down a few days ago and ever since that time it boots the bios screen where you have to press F1 to enter setup or F2 to load with the default settings. If I press F1 I enter the bios setup and if I press F2 it's boots fine after that and it seems to work normally. Still I'd like to know what the problem is and if I can fix it before it might get worse. I don't know anything about bios settings or anything like that so I could really use some expert advise. Already tried updating my bios, I have the latest bios version now but that didn't fix the booting problem.
Greetz 08Ray
Posted on Jan 22, 2011
  • jon doe Aug 04, 2012
    I'm having the same problem... has this question not been answer on any forum??
Asus eee pc not booting
Try to go to BIOS and run a HDD test.
To Go to BIOS turn on the NoteBook and Keep Pressing F2 and you will enter the BIOS set up.
Search for Hard Drive Test Option from the Menus
If the Test Passes then you need to Reload the Windows OS or if the Test Fails you need to get a New HDD
Jul 14, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Eee pc 1005ha bios setup won't start, it just hangs while entering, just after detecting the hard drive.
Maybe you are not giving it enough time to get into the setup.
Let it sit for a while and see what happens.
May 30, 2012 | ASUS Eee PC 1005HA PC Notebook
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
Asus Eee 1005HA hangs on boot
This works for my Asus Eee PC
1. Shut down and remove the battery.
2. Press the power button 10 times, next 1 minute pressing down.
3. Remove the memory and at the motherboard you'll see a clrrst (clear reset cmos..)
4. Short these 2 tiny pads by placing a tiny screw driver for 5 seconds, plug the power adapter and turn-on the switch, next wait at least for 3 seconds. Remove the power adapter.
5. Place back the battery and turn-on. You'll see the same screen (Logo of Asus) then patiently wait for at least 10 minutes or more. That's it.Good luck.
Feb 16, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have an Asus Eee PC 1001ha series, with Windows XP. Whenever I turn it on it displays the grey asus screen with the phrase "press F2 to run Setup, Press TAB to display BIOS POST Message",...
My suggestion is better to send it on the technical around on your area, to prevent any further damage. And also backup your files by removing your hard disk and slave it to other computer. Just use any converter of mobile hard disk to become a USB type drive. Hope it helps thanks.
Sep 21, 2011 | ASUS Eee PC 1000HE Netbook
When i turn on my eee pc i get the message "Press
Please pull out your hard disk and put it back after 10 seconds. Your laptop will be start as normally.
Thanks
Jun 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
ASUS Eee PC 1005 HAB it won go after the "press f2 to run setup, press tab to display BIOS POST message" screen. When i turn it on it makes a sound inside the computer for like two seconds after...
It seems something wrong with the Hard disk, remove the Hard disk and memory card and reset them, then start your computer,,,If doesn't work, try more times, remove graphics together is better
Jan 10, 2011 | Computers & Internet
I was told press F2 simultaneously on startup, nothing happened
You need not to press F2 or tab or escape unless you need to do so. If your system is ok, it'll automatically boot up, but if there's boot up problem with your system, then that's different. Thanks for using FixYa.
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
1,291 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
