Question about JVC Car Audio & Video
I recently installed a JVC KD R610 Deck, and I have the wiring harness all connected and everything. When I hit the power button it will not turn on. If I hit the "display" button, it will display the time for a moment, and if I hit "eject" it will attempt to eject a cd, but I cannot get it to turn on.
  • estull1 Dec 31, 2010
    I am using a wiring harness, it is a 2001 Pontiac Grand Am. I have all of the colors matched correctly, could the harness itself be mismatched?
    Genius:
  • 1,456 Answers
Hello
best thing is to pull the radio out and check the red and yellow wires red wire is the ignition switch and your yellow is the always on for your memory if you like you can connect the red and yellow wires to the yellow one that will work with engine on or off but every time you get out the car you will need to turn the radio off manually i suggest pulling the radio out and checking the 2 leads as far as you can it could also be a fuse gone but it wouldn't work when engine is off.
There could also be a short most likely in one of the speaker wires. If not a speaker wire, then one of the power wires is touching ground. This short shot through your radio and blew the fuse. On the way through the radio, it burnt an internal circuit. It can be repaired at an electronic repair shop so the short can be identified.
Posted on Jan 01, 2011
  • 15,935 Answers
It appears you have the Constant power and Switched power reversed.
Have you used a wiring harness adapter - or have you cut the factory plug?
What car is this going in?
Year/make/model?
Thanks!
Posted on Dec 31, 2010
I have a 1991 buick regal limited. took out the stock radio and cassette player and put a jvc kd-r610 in its place. hooked all the wires up,grounded it,and it doesnt turn on
Double check that the wires are connected properly. Also verify that all of the leads are operating as they should with a multimeter. If you used a harness adapter verify both before and after the adapter.
Mar 15, 2011 | JVC AM FM CD DET FACE CAR STEREO
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
My jvc kd-g300 head unit shorts out and comes back on when i turn it up louder than 20-25 esspecially if the bass is turned up
Could it possibly be a loose wire behind ur deck that connects itself when bass starts to hit? Just an idea of a possibility..otherwise check all possible fuses that could be responsible for the loss of power.
Sep 25, 2010 | JVC Sirius KD-G300 CD Player
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
Wired and Installed a jvc KD-R610 deck in my 95 mustang and deck will not turn on
You should verify your wiring .Also check all fuses. that is on the radio and for the power wire (red) .
May 12, 2010 | Car Audio & Video
Jvc kd-r200 wont power on
you have the red and yellow wire on the radio mixed up switch them
Apr 25, 2010 | JVC KD-G110 CD Player
My car stereo won't stay powered on.....
your constant power is not working only your ignition power is
Mar 31, 2010 | Car Audio & Video
JVC KD-AVX1 Sirius Just Quit
Hi guys i need help i bought a use KD-AVX1 and i don't know how to use it i need help how to get a manual for my radios appresiated your help.
Apr 29, 2007 | JVC KD-AVX1 Car DVD Player
Car Audio & Video Logo
154 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
