Question about Jl Audio 500/1 Car Audio Amplifier
I have a jl audio 500/1. I had the amp professionally installed. The amp played for 2 days and no it has no sound but the power will come on. what could be the problem. I have new rca jacks, 4 guage power and ground which are firing and grounded very well. I can not think of anything else that could be the problem. please help, i want my bass back.
  • 162 Answers
Go back to where you got it installed and ask them to fix it.
If you don't want to do that I would recommend going to another good car audio shop and getting them to check it out.
You can test it yourself by hooking up an iPod to it using a Headphone to RCA cable.. test at low volume first.
Posted on Feb 04, 2011
I have 2 jl audio 12w6 and one jl audio 500/1 amp, and the speakers make a weird noise..sounds like the voice coils are bad..so my question, is there any way i can fix them or i need new speakers?
yeah you can always take it back to your local JL audio dealer, i wouldnt do it your self unless you done it before and got it down like a ****. A lot of people i know tryed and always ending up tossing it out.....
May 07, 2010 | Jl Audio 12W6 Car Subwoofer
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Amp isn't powering subs and speakers
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
Fried amp
Hello zadiel89,
Out-of-warranty JL Audio products are normally repaired through JL's authorized dealer network.
To locate your nearest JL dealer, enter your zip code in the box on this page, select "radius" from the drop down, and click "find".
http://mobile.jlaudio.com/dealerfind.php
You can email JL directly at: technical@jlaudio.com
Hope this helps.
Aug 21, 2009 | Jl Audio Car Audio & Video
JL Audio 500/1 Amplifier "Thermal" light flashing
Re-check all the connections to the speakers, The uPC monitors all the outputs and if any are taking more power than they should, the uPC shuts the amp down to protect the internal components. Don`t use tape joints alone, try to run the cable the full length without any joints. If you do have to piece the wires together, solder them and stagger the connections, in other words, make one lead shorter than the other so that if the tape does come off, the offending connection is well away from the other so they can never meet or connect to each other. Ian
Jul 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Feb 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
I HAVE A JL AUDIO MONOBLOCK AMP 250
It indicating that the power output is too loud and possibility of speakers may get damaged if played at this volume for long periods. When the loudest sound is played the led light mightshow its loosing its brightness and dims in time with the sound level.......................sodeep
Jan 17, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL audio 500/1 produces barely any sound
have you checked the input sensor on the amp?
Oct 28, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
