Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Freezer temp is increasing...and the partician (bar) between the freezer and fridge is extremely hot?
  • Barrett Palumbo
    Barrett Palumbo Dec 31, 2010
    is this a new unit or old
  • KitchenAid Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 01, 2011
Frig not working freezer is great
If your fridge is old you maybe have a leak, crack, blockage in the fridge part...or at first step check your temp controls ...should be knobs in freezer as well as in bottom of fridge...sounds simple but overlooked at times. If fridge is a n older model especially if its located in a hot room it takes alot of freon and at times they are not equipped to get cold in extreme hot storage temps.
Jul 07, 2012 | Amana Refrigerators
I moved my freezer to the shed 6 months ago as soon as the cold weather hits the freezer has stopped working. The light is on inside and out, defrost timer is working. I?m thinking thermostat or compressor
Freezers & Fridges were not designed to operate in extreme cold conditions. They are designed to operate at room temp. It could be sending an inaccurate temp signal to the thermostat due to extreme low temp outside.
Nov 27, 2010 | Refrigerators
The center bar between the freezer and refrigerator is very hot to the touch. Also about halfway down on the freezer size is also very hot. The ice cubes also seem to be smaller
Heat is normal but the freezer may not be clod enough. Check temp in freezer(0 deg F or -18 C. Also check rear wall of freezer for frost . If so you have a defrost problem which will raise the temp in the freezer. Also check that the condenser fan in the rear bottom of the fridge is running and the condenser is clear,
Nov 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
We have a Hoover No frost refrigerator/freezer. There is no control for the fridge temperature which is now running very cold (it freezes drinks, etc.). What can I do to increase the temperature of the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | Hoover HCA391FFK Bottom Freezer...
Admrial LTF2112AR fridge not cooling
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Sep 12, 2009 | Refrigerators
Freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Aug 02, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Beko fidge/freezer (model cg975ff) overheating
My general maintenance seems to binging the temp down slowly.thanks
Aug 29, 2008 | Freezers
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
65 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
