Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Need part # for lg refrigerator filter drier on lfx25960st i need to change compressor
  • Anonymous Mar 12, 2014
    LG refrigerator need to change the filter
  • LG Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Posted on Jan 01, 2011
Why do we have to replace compressor all the time???
This compressor burned out due to lack of maintenance, condenser coils were clogged 90%. compressor overheated and blow out. I made video how To change compressor and filter dryer. Its a beer cooler. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Apr 27, 2014 | True Refrigerated Sandwich Prep Table 72"...
I have a LG refrigerator model no. LFX25960ST that stopped working. All my meats in the freezer defrosted and the upper fridge is also warmed. I can hear the fan running. I unplugged it and plugged back...
it is not a great idea turning a fridge off and back on straight away. It will overload the compressor and cause it to trip out. I would suggest that the starter relay has failed on the compressor but if the fridge has been left to cycle on and off too many times, it will damage the compressor. Turn it off and get a fridge tech to look at it and confirm the fault.
Jan 28, 2018 | LG LFX25960ST Stainless Steel French Door...
Fridge not cooling. Shifted house 2 days back. Before it was alright.
Your fridge systems under chocked. Whenever transport refrigerant unit you should not lift down wards on suction side which will lead compressor oil thr' discharge line. When compressor on, it will pump the oil.It get chocked on filter drier resulting to no cool.
Solution. Remove all gas, and also filter drier. Now flush out condenser side separate and evaporator side separately.Then replace filter drier and vacuum the system.Now do gas charging. Thanks. helpful?
Jan 30, 2011 | LG LRFD25850 French Door Refrigerator
My LFX25960st LG stainless refrigerator ice maker isn't working, it'll make a few ice cubes every couple of days and now on the touchpad it says ER IF and i can't touch anything, how can i fix my problem?
Remove the fresh water hose coming into your refrigerator and check the water flow with a small bucket. This actually sounds like a replace water filter error. Some IF error codes break down to Inline Filter.
Jul 31, 2010 | LG LFX25960ST Stainless Steel French Door...
What does if mean when the display reads ER CF code on my LG LFX25960ST fridge?
it means there is a fault with the units compressor fan you will notice the fridge is running with less noise you will need to call a service man to come fix it good luck
Apr 21, 2010 | LG LFX25960ST Stainless Steel French Door...
Model GSC130481AG, S# 0808548576 The common wire to the compressor rubbed through the wire insulation and melted a hole in the discharge line from the compressor. Upon loosing all of the refrigerant the...
You have a restriction in the system. Probably in the TXV or orifice in the A/H.
The burn out sent trash/fragments through the system. I would open the sytem and blow nitrogen through, then pull a deep vacuum.
You may need to install a low side filter/drier. When you open the system change out the high side drier again for sure.
Jun 26, 2009 | Goodman Heating & Cooling
Kitchen aide superba refrigerator side by compressor not working
how do you believe that... what is your problem? give me some details... www.whirlpoolpartssurplus.com is still open call them
May 02, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
