Question about GE JE1540 Microwave Oven
I have a GE microwave model JE1860SB 001 that is 10 years old. For the past year it intermittently fails in the following way. When it is heating for a little while the oven light gets very dim and the sound of the microwave changes. Stopping and starting the microwave usually fixes the problem. This happens at various power levels.
  • chrismigdal Dec 31, 2010
    I had considered a new unit but the problem is that the microwave is built in and newer models are a different size, so putting in a new unit is a fair bit of work. Since the microwave is in cosmetically great shape, I was hoping to get it repaired.
    Is there a way to determine if the problem is the magnetron or something else ?
    Thanks
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
sounds like you may have a defective magnetron, or another failure. due to the age and parts availability. you may think about a new unit.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
  • Barrett Palumbo
    Barrett Palumbo Dec 31, 2010
    a service company, can figure that out.. the big problem is getting parts..the factory's provide a 5 year window on parts..that's the issue... to pay 60.00 to 125.00 for a service call to find out no parts for the unit..
  • Barrett Palumbo
    i forgot you can contact ge for a replacement size
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
I have a model GE JVM1653BD 001 microwave. Sometimes when it runs it makes a loud growling sound. It appears to be heating normally though. Intermittantly makes this noise.
I have the same model ending in 003, and it has made this noise for most of its life of several years now. Every now and again it runs quietly.
My theory is the cooling fan (not the hood fan) is making noise. The problem began within the first year of operation, and up till now everything is in good working order otherwise. There is no odor of failing parts.
My installation book has no electrical circuit diagrams, and I came upon your question when searching the topic.
Oct 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge model JVM1850. It is 6yrs old. Today it suddenly did not heat a frozen small item thru. Does this sound repairable or do I need to consider replacement? It is above oven.
well!!!!!! its 6 years old,,,,my bet is the manatron has failed,,,and thats a pricy part to buy and have fitted,,,
you may find in the long run its cheeper to just buy a new microwave,,at least it would be a new one and not 6 years old! and not a patch up job
Jun 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM 1443 - Unit makes a deeper noise and will not heat
Hello mrobinert,
The sound you may be hearing could be the filament transformer breaking down or the magnetron tube failing ..they will arc and eventually fail. If you aren't getting any microwave energy ( to heat material in the cooking compartment) then in all probability it is either the transformer, magnetron or high voltage capacitor.. None of which are something you want to repair yourself... My advice is that if the cost to repair exceeds teh cost to replace then just buy a replacement model. If yours is under 1 year old, then you may be able to negotiate and get a replacement from the store where you purchased it.. If it is older than a year, it's probably cost effective to just buy a new model.
Regards,
Rick
Nov 23, 2008 | GE Microwave Ovens
JVM2050 Doesn't cook food sometimes
Not the magnetron if intermittent. Probably a bad smartboard. Easy to replace if you know the basic precautions to take.
Mar 05, 2008 | GE JVM2050 Microwave Oven
My GE Spacesaver Microwave is "Trippin!!"
I had a similar problem and found that unplugging (or in your case leave the breaker off) for at least 12 hours then plugging it back in solved the problem.
Jan 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
608 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
