SOURCE: AMW F199B 19 Inch LCD Monitor - No Red
I just changed PC and and I have a "AMW F199B" monitor that will not produce sounds now. I do not have any of the original software for the monitor. What do I do?
Thanks
SOURCE: 6 mo old amw monitor A913B 19
Same Monitor, same problem. Solution: I changed the colors setting to 16 bit from 32 bit, and that cleared the problem. I then changed back to 32 bit and it still worked. How long, not known yet. So , go to display settings, find COLORS: and then change to 16 bit.
SOURCE: I bought a used samsung 931b 19 inch monitor and
you need either a dvi-d or a dsub cord depending on whether your computer has analogue or digital outputs. if you look on the back of your computer, dsub is blue, dvi is white. this monitor has inputs for both. the cords are available at you local bestbuy, radio shack, or office depot.
SOURCE: I have 19 inch monitor, it goes on for 2 seconds a...
LCD monitor? Brand?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: Monitor went out and only
Use a flashlight and shine on your screen. Look carefully is you still see the image on the screen. If you do, this is an indication that the monitor is still working, but the backlight has failed. A common solution with backlight-failures is to open the monitor, and look if you see any "swollen" capacitors (http://en.wikipedia.org/wiki/Capacitor_plague). If you see one you should replace it. Only open your monitor if you know what you're doing and have basic knowledge of electronics and soldering.
