Question about Mitsubishi WS-55513 55" Rear Projection HDTV
My ws55513 tv has the blinking light on , i have replaced the 4 capistors on the dm bosrd thst did not do snything to help any suggestion.
  • 1 more comment
  • rblundell1 Jan 01, 2011
    SORRY IT TOOK SO LONG TO ANSWER I CANNOT GET THE GREEN LIGHT TO STOP BLINKING. I HAVE PUSHED THE RESET BUTTON BUT NO LUCK. I DO NOT HAVE THE SERVICE MANUEL.
    YES I DO NEED THE SERVICE MANUEL.
    THANKS I WILL LET YOU KNOW HOW IT TURNS OUT.
  • 10,594 Answers
Need to read out error code.
Let green light blink and wait till is stops then press and hold Device and Menu buttons on tv front for 5-6 seconds to activate error code read process.
Now count light blinks, it will blink in two patterns then stop and this will repeat 5 times.
Light will blink for example 2 times then 4 times, stop, again 2 times then 4 times and stop. here error code would be 2-4
Let me know how many times that light blinks to find out possible cause of problem.
Do you have service manual of tv?
Thanks.
Posted on Dec 31, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jan 01, 2011
    OK, it seems power supply issue that is not proper to boot up tv.
    You should have service manual copy to test power supply output volts and troublshoot as mentioned in service manual.
    Let me know to upload copy for you if that helps.
    Thanks.
    OK, I'll upload service manual file for you and give you download link, rest is your own skills to repair your tv.
    It is complete service manual and its approx 32mb pdf file.
    Thanks.
    Click HERE to download service manual file.
    I have done my part here, rest is your expertise because tv is in front of you, wish you good luck.
    You may please accept solution now.
    Thanks
Mitsubishi ws55513. I replaced the 4 caps on DM board. Light still blinking. I found bulging caps on convergence board. 2200 by 16V. Going to replace them. Could convergence ICs give me same symptom? Cause...
First up we are gonna have to figure out if the blinking LED sequence is triggered by the convergence circuit. Did you try the error code operational check? If yes then please let me know whats the error code so that I can tell you whats the source of the problem.
Jul 06, 2011 | Televison & Video
Ws55513 ticking noise and no picture after replaced caps
have you properly installed the back cover plate for the DM module, which has (apparently critical!) grounding straps essential to the proper functioning of the DM module - the DM might not be getting proper grounding. check it.....& let us know here..
Mar 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws55513
Hi and welcome to FixYa,
Appreciate the direct "Ask Me". My compliments on accomplishing the replacement of the 4 1000 uF/16V capacitors on the DM board.
To your concern, the blinking is still there even after having replaced the caps, a friendly reminder, the capacitors are polarized, there are specific +/-. Additionally, you may have to check the pico fuses. They would be on the backside of the DM board and would be very close near to the solder points of the 4 caps. They are marked FB900, FB901 and FB902. Rating would be 125V 4amp. Possible source maybe here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws55513 Blinking light -capacitors changed
check the resistor chips on the bottom side of the circuit board solderd directly to the traces one or more may be open.
Mitsubishi ws55513 Blinking green light- replaced capactitors
Hi again,
It would seem that you posted twice. My compliments on accomplishing the replacement of the 4 1000 uF/16V capacitors on the DM board.
Toyour concern, the blinking is still there even after having replacedthe caps, a friendly reminder, the capacitors are polarized, there arespecific +/-. Additionally, you may have to check the pico fuses. Theywould be on the backside of the DM board and would be very close nearto the solder points of the 4 caps. They are marked FB900, FB901 andFB902. Rating would be 125V 4amp. Possible source maybe here.
Justa start, do postback how things turned up or should you need additionalinformation. Good luck and Thank you for using FixYa.
Blinking light will not turn on
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
May 06, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
A quick fix for this is to use a hair dryer to heat up the capacitors and then plug the tv back in.  It should only take about 90-120 seconds to heat them up depending on how hot the dryer is.  The cap's are located on the right side.  Take the front cover off the TV, and heat up the box that is about the size of a small cable box on the right side.  Once the cap's are warm, they will stay warm as long as the TV stays plugged in.
Scott out
Jan 03, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Nothing works
You will need the DM module repaired....requires replacing
four 1000mf 16v 105 degree capacitors with a bit higher
voltage = 25v or 35v.....if too tall, lay them over 90 degrees on
to board.....there are many entries concerning DM module
rebuild...........if you need further assist,let me know...T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi HDTV 1080
The set is trying to tell you somthing by blinking this light. And the bad news is that it's sayiny the DM board is not booting up, there are several problems that might cuase this all from bad capacitors to a shorted diode or a compleatly replacing the DM board. but all these are not for the weakend tv tech this one has to go into the shop
Oct 27, 2007 | Mitsubishi WD-62827 62" Television
Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
277 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
