Question about 5BCR07P Remote Replacement Transmitter for APS997A
How do i program my prestige 5bcro7 - 5BCR07P Remote Replacement Transmitter for APS997A
    President:
  • 1,932 Answers
Here is the programming guide for your audiovox 5BCR
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/5BCR05-5BCR.pdf
Thank You
Posted on Jan 01, 2011
Code alarm protx6 fob programing
I would either go to the website for the manufacturer of the keyfob and search the troubleshooting section or get the company phone number and call them and get instructions for the programming codes. good luck.
Apr 16, 2014 | Audiovox Prestige Code Alarm Remote Alarm...
Prestige remote start APS-901C on 2007 toyota yaris auto i just installed r/s and tried to program the tach. no response from r/s. led blink twice . no tach or low tach input. checked the wires 5 times...
The tach wire for the 07 Yaris is light green at the data connector under the dash. If you have chosen to go to an injector or coil and, the system responds with low or no tach, go to the tach programming sequence again but, while programming the tach increase the rpm by putting your foot on the accelerator and holding the rpms at 1500 during programming.
Your other option is to program the system for voltage instead of tach. When programmed for voltage, also program for timed output instead of average.
Apr 21, 2011 | Prestige Remote Start
I need to re-program the remotes to my alarm. It is a prestige aps255a. Just to lock and unlock all the doors. To arm and unarm is already programmed.
Huh? Pressing the lock button arms the alarm AND locks the doors. Pressing the unlock button disarms the alarm AND unlocks the doors. If this is not happening either there is an issue with the wiring from the alarm to the car or, with the vehicle's door locks.
Apr 20, 2011 | Audiovox APS255A Car 2 Prestige Platinum...
Have a prestige remote start that was installed and only worked for one week. now the remote beeps but doesn't start or lock/unlock any doors. remote says inhibited . all doors are closed as is hood and...
If this is the Prestige 997C, there is a remote starter disable feature that can be activated through the programming switch. When it is active it will display "inhibit' on the screen. To deactivate this feature, press and hold programming switch, turn key on, off, on, off, on then off. When the hood pin switch is not making contact with the hood when closed, the screen will display inhibit. When the brake shutdown wire is active the screen will display inhibit.
Feb 27, 2011 | Prestige Remote Start
Halo..i got a little problem wt my router.. ZYXEL PRESTIGE 660H-61 i forgot the password..can anybody help me to recover or break it.. I've tried to push reset button and use default password '1234' but...
if you can access net, go and download installation program for your router and re-install it.Or better if you have original CD. The only way to solve your problem is to reinstall program.
Oct 26, 2010 | Zyxel Prestige 660HW Wireless Router
How do you progam a new one
Did you (or anyone else) find out how to program this. I need to program one as well. Elenib@sbcglobal.net
Oct 15, 2010 | Prestige Aps95bt2 Elvat5c Replacement...
How do i program the remote start function on prestige 997
email me i cant help you,i need to know the model of the alarm and what kind of vehicle is installed here is my email reynosaelectronics@live.com.mx
Mar 13, 2009 | Prestige Remote Start
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
5BCR07P Remote Replacement Transmitter for APS997A Logo
631 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
