Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Water in door but none to ice maker-why - KitchenAid KSCS25FKSS Side by Side Refrigerator
  • 472 Answers
Couple of things to check make sure there is no obstruction where the fill tube comes into the icemaker... if ice builds up in plastic tube it will not allow to come into ice maker... if there is ice there most likely the water valve is not closing all the way... these are normally dual water valves meaning one solenoid goes to ice dispenser /water dispenser and the other works the ice maker good luck
Posted on Dec 31, 2010
Ice Cube maker in Frigidaire FRS23R4 refrigerator not wotking
The first thing to check is to see if there is any ice in the fill tube, where the water comes in, preventing any more water from coming in. If there is none then the water valve is bad, even though the water in the door works. Its a dual solenoid valve so if one goes bad they both have to be changed
Jun 05, 2012 | Frigidaire Refrigerators
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Ice maker malfunction does not make ice. was making too much ice now NONE
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker wont work
If the ice maker has completely stopped producing ice.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
If the ice maker is producing ice poorly.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve. First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 27, 2010 | Samsung RF265AA Bottom Freezer French Door...
No water to ice maker.Ice maker quit making ice.
What I found was the problem was that I had not changed the filter on a regular basis.Because of this the water flow to the ice maker was restricted.What this caused was the water inlet tube on the ice maker to freeze up.On my unit it is a black rubber tube about 11/4 long on the right side.You can see it if you know what you are looking for.If you squeeze it you can tell if it is froze or not.You can use a hair drier to thaw it out or squirt water up into the tube .It does not take very long..To make sure it is clear disconnect the tube on the back of the fridge and blow into it.If there is no restriction the tube is clear.After you have determined the tube is clear add water to the ice tray so the unit will make ice this will start the ice maker to cycle.Its making good ice now.
Jan 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not making ice
Hi
If The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 29, 2009 | Estate TS22AFXKQ Side by Side Refrigerator
LG refrigerator french door icemaker not working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
No water going to the ice maker
Is the sensor that senses a full ice bin clean....it is a little light or it is a lever. If is thinks your bin is full it probably won't run water. There is a separate valve for the ice maker. It may be bad or have a bad connection on it.
Jan 27, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
143 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
