Question about Frigidaire GLER341A Electric Dryer
My dryer will not turn. I have tried um plugging it, resetting the breaker. The time comes up and I push the start button but it will not run.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.You will need to replace the door switch with this part.
Posted on Jan 01, 2011
Why won't my Kenmore 80 Series dryer turn on when I push the start button even though the breakers are not tripped
You either have a bad off/ on switch or one of the wires iis burned of f the plug.
Feb 04, 2015 | Kenmore Dryers
Whirlpool GEW9869K beeps when plugged in and lights flash
pf error is power fault most of the time. circuit board maybe! lots of things to test... but main circuit board is my guess.
Aug 31, 2012 | Whirlpool GEW9868K Electric Dryer
Dryer will not come on
send model number,is it gas or electric?check to make sure you have power where the cord connects to dryer and sent info so i can help you
Feb 24, 2010 | Kenmore Dryers
Dryer want start up when you push start button but its power up light comes when open door
You most likely have a blown thermal fuse inside the dryer or a bad door switch. First reset your home breaker. some times the breaker will drop a 110 volt leg and will work if you reset it.
Dec 15, 2009 | Kenmore Dryers
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
They dryer will not come on when the start button is pushed
push breaker hard off to reset then on3 times...
...belt
...motor
...timer
plug and cord
Aug 17, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Dryer will not turn on
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 30, 2009 | Dryers
Power surge and breaker went off, turned it back on and washer comes on but not the dryer, is there a reset button
The dryer is on a different circuit as it is 240 volts. Look in your breaker box and find the breaker for it (it should be tripped half way). Turn it completely off and then back on. There is no reset button for it. Make sure the plug is securely pushed all the way into the outlet.
May 12, 2009 | Maytag LSE7806A Top Load Stacked...
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Frigidaire GLER341A Electric Dryer Logo
46 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
