Our fujitsu aircon model number arje4 keeps on flashing back to the timer...we dont want to you the timer and we dont know why it was set like that..it also short the fuse outside in the electricity box...
bobotfel
  • 236 Answers
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Posted on Jan 07, 2008
jfpogie
  • 104 Answers
SOURCE: Air Conditioner - Fujitsu - 24R1 - Electrical Installation
thanks
Posted on Jan 24, 2008
koolbreezes
  • 540 Answers
SOURCE: My fujitsu split type aircon is not working, the
Can you check the service manual for the diagnostic code?
Posted on Dec 22, 2009
  • 10 Answers
SOURCE: How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Posted on Jul 15, 2010
  • 5370 Answers
SOURCE: My Fujitsu (AST9LSACW ) timer
Yes two flashes is indication of temp control setting problem.But still check this too:--- This are other reasons of poor cooling:-- ? Is the Air Filter dirty? ? Air the air conditioner's intake grille or outlet port blocked? ? Did you adjust the room temperature settings (thermostat) correctly? ? Is there a window or door open? ? In the case of Cooling operation, is a window allowing bright sunlight to enter? (Close the curtains.) ? In the case of Cooling operation, are there heating apparatus and computers inside the room, or are there too many people in the room? ---------------
? The air conditioner power has been interrupted by a power failure. The air conditioner will then restart automatically in its previous mode when the power is restored. ? Operated by setting before the power failure. ? If a power failure occurs during TIMER operation, the timer will be reset and the unit will begin (or stop) operation at the new time setting. In the event that this (kind of timer fault occurs the TIMER Indicator Lamp will flash . ? Use of other electrical appliances (electric shaver, etc.) or nearby use of a wireless radio transmitter may cause the air conditioner to malfunction. In this event, temporarily disconnect the Power Supply Plug, reconnect it, and then use the Remote Control Unit to resume operation. ----------------- Also if your require user manual for your Fujitsu unit.Please click on the link below:-- http://www.fujitsugeneral.co.nz/scripts/get-manual.pl?manual_id=40 ------------ This should help.Thanks.Helpmech.
Posted on Jan 20, 2011
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
Fujitsu inverter ASTA34JFC NOT BLOWING COLD AIR TIMER LIGHT FLASHES AT TIMES
Count how many times the timer light flashes before it pauses and repeats. The number of flashes will give an error code to diagnose the problem. Confirm the number of flashes is correct because one flash number out will be a completely different problem.
Sep 25, 2016 | Fujitsu Heating & Cooling
My Fujitsu air con keep flashing operation,timer and economy .off the plug took out and on back still the same.took out the batery from remote and put back still the same..plss help me
It's asking you what mode you want to run your unit in. Do you want to run it in heating or cooling (operation), do you want to run it with economizer mode (economy), or do you want to run it with a timer setting (timer). Do cooling, no economizer, and no timer. This will make your unit run off off the setpoint you want. I.e. 72 degrees
Aug 05, 2016 | Fujitsu Heating & Cooling
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
Timer light on fujitsu heat pump flashes not heating
the light flashing indicates there is a problem. you can try reseting the system by turning the power supply off and back on again 30 sec later, if the same thing happens you need to count the number of light flashers and that relates to a fault code
Jun 20, 2012 | Fujitsu Heating & Cooling
Drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Jun 28, 2009 | Fujitsu Heating & Cooling
Fault with 241C Aircon
This happen when you use the inverter for a long time and start getting old and over heat...try to power down the units and keep it for about an hour and then starft them again and try to install a small fan to keep them cool.
May 14, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
