Question about Tascam Audio Players & Recorders
Hi, My TASCAM DA-20 mkII DAT recorder is holding onto a tape. It will play the tape and there are no error messages, but the tape will not eject. How do I get the tape out without breaking the DAT recorder. (The tape has been copied so I can sacrifice it no problem. Thanks for any help!
  • Tascam Master
  • 1,267 Answers
A Technician usually has to get a tape out of a machine when this happens. In radio when I was Chief Engineer for several stations in Chicago I would send my defective decks to Russ at New Jersey Factory Service in Emerson NJ. He knows how to fix these units.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
Posted on Apr 04, 2013
2 Suggested Answers
satavlad
  • 405 Answers
SOURCE: I have a Tascam DA-30 which ejects the tape
Many different things could sause a problem, belts, mode switch, capacitors in capstan or head motor drive circuit. Hard to say what exactly is wrong with the machine without looking at it.
Posted on Dec 04, 2009
How do I fix a Tascam DA-38 Multitrack Recorder?
It needs cleaning and new belts some of which are very hard to find because they are smaller than a dime. It can be fixed if the Pinch Roller is not cracked.
May 30, 2015 | Miscellaneous
My TASCAM DA-20 Mk II DAT doesn't play back any of my tapes. It still appears to record OK, but there is no level meter or sound or track finding when playing back, though the tape seems to be run
Hi Julian,
There is a lot that can go wrong with these miniature helical scan systems. When I had units like that I packed them off to Russ at New Jersey Factory Service and they were restored. I am not sure about parts like drums at this point but Russ is your best chance to get it working again. He has corrected CDRW and DAT as well as just about anything Tascam makes and he even fixed some Sony units too. I know him as the counterpart to the Chicago Factory Service facility when it was open. He was the Manager in New Jersey then.
201-967-0060
Fax 201-967-0062
Mon- Wed 8-4 Thurs 8-3(July-Aug) Closed Fri Sat by appt.
Aug 23, 2012 | Tascam Audio Players & Recorders
Where can I get tapes for a tascam da -30 mk2 and what are the tapes sizes?
You need what are called "DAT TAPES". Just like Blank analogue audio cassettes they come in a range of lengths fro 15min to 180min. You'd be better off to use something like a 60 or 90min IMHO. Dat tapes can be purchased from places like "studio spares" or any other PRO media supplier. They can be quite pricey. I tend to buy mine in bulk on ebay.
Before you ask, not there are not different tapes for different machines, but the btands do vary. I use either HHB or AMPEX. DO NOT USE COMEPUTER DATA BACK UP CARTRIDGES as a cheap alternataive.....they are different and end up giving you a lot of loss and errors over the years...sometimes instantly (Tale it from experience!)
Best Of Luck
Sep 07, 2010 | Tascam DA-30MKII
TASCAM DA-30 tape transport error
When you use any cleaner or lubricant it must be only for the moving part and must never stray into the transport section. Also what is required if there is any frictio is to dry wipe and set. Now when you lubricant got sprread into the head, the oil will act as a great adhesive at higher speed and got the tape entagled. So please wipe dry all the oil of the headd and do nto damage the head with the wipe touching the delicate ferrite heads in the slot, DO NOT TOUCH THIS SECTION but with an even paper with soft brushes. Now check you reel drive and see if there is dirrt lodged in clean and reset., put the set on for regaining lost values as many electronics capacitors may have lost value by drying. If the tape up does not move it is a mechanical problem and you must check for the drive and the friction wheel. If however the reel works and the count does not happen and you get the error , then your reel sensor is faulty. Check these points and confirm, Hope this advice helps, Good day.
Jul 23, 2010 | Tascam DA-30MKII
Dec 03, 2009 | Tascam Audio Players & Recorders
Looking for some further insight into 'Error 03' messages
HI...
The unit will need to have the cover pulled off and the tape drive mechanism unfastened , turned over and,the VERY small belt needs to be replaced
SBO1.55 belt from www.studiosoundelectronics.com
Mar 20, 2009 | Tascam DA-30MKII
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Need a tec to repair
I can help you if you are in Queensland Australia. :)
Jan 19, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Da 38 8 track audio
This is a nice DAT recorder for its time. This unit uses a drive gear system for the FF, RR and the take up reels. Try the ff and rr, if they work, I am quessing there is a bad take up idler clutch assembly.l If the ff and rr does not work, the drive belt(s) are most likely bad. Good Luck
Jun 23, 2007 | Tascam DA-30MKII
Tascam 102 mark 2 cassette
there is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Apr 13, 2007 | Tascam 102 MKII Single Dual Cassette Deck
215 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
