Question about BonJour BJ11300 Wine Cooler
Do not know how to work it, because it came without instructions. How do I get it to cool and what setting for White wine and what setting for Red (burgundy)? Many Thanks, BK
  • wmbradley_ke Jan 02, 2011
    Make "BonJour" ("Sylvania Electric Wine Cooler"). Model "Wine Cube Deluxe" W.C. 605-Serial # 67001172
    Thanks, BK
  • 8,404 Answers
Should just have to plug it in ... probably doesn't have a precise setting ... White wine may be cooled to around 55 degrees. Red wines should never be chilled.
Thanks for your visit today
Posted on Jan 04, 2011
  • 8,197 Answers
May I get the make and model # to help you more
Posted on Jan 01, 2011
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
What are best dates to drink red wine?
There is no magic date. Just make sure to chill it for a hour before drinking. I know it sounds weird but that is how it is done. For white wine and it's been in the refrig. you need to let it sit a hour before drinking. Most folks drink white wine too cold and red wine too warm.
Sep 06, 2014 | Wine & Spirits
I know that wines are made from grapes, but why are some wines red, some pink, and some white?
White wines are most often made from green/yellow grapes. Red wines get their coloring from being in contact with the skins of red grapes during the fermentation process. Finally, rose wines can attribute their coloring in one of two ways - either by being in short contact with red skins or by mixing finished red and white wines.
Feb 03, 2013 | Wine & Spirits
Can I keep red and white wine in the same temperature?
Not recommended. Red and white wines are different worlds and in order to preserve the wine better you need to keep the wine in the recommended temperature: Red wines at 12.7-15.5 C and white wines at 9.5-13.3 C
May 29, 2012 | Furniture
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
Mar 29, 2010 | Emerson (025806803716) Wine Cooler
Haier wine cooler, how to operate? No manual.
If you just want to use the factory settings then push the red or white button depending on what you store the most.
Or you can set it yourself by pushing the red and white buttons together for about 3 seconds- the temp display will start flashing-then use the red and white buttons to set the desired temp-then push the set button
Jun 11, 2009 | Haier HVF060A Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
I want the bottom to be reds and top to be whites
I don't think you'll be able to do this without some modifications to the unit.  The wine cooler is designed to blow cold air into the bottom section, and the top section cools down by spillover of cool air flowing between the glass door and the temperature control panel.
I guess if you could figure out a way to turn the panel that separates the top from the bottom you could make it work.  You'd have to switch the temperature sensing leads on the thermostat inside that panel(that would be pretty easy) and you'd probably want to flip the LED indicators so they read right-side-up.  The main issue would be that the screw holes for mounting that separator panel are all on the bottom, but when you flipped it, they would be on top with no holes in the walls to screw them into.  If you are willing to do that, you might be able to make it work as you would like.
Good Luck!
Dec 27, 2007 | Danby DWC283BLS Wine Cooler
BonJour BJ11300 Wine Cooler Logo
216 people viewed this question
Top BonJour Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a BonJour Refrigerator Expert? Answer questions, earn points and help others
