Question about Frigidaire 24 in. GLDB957A - Multiple Color Energy Star® Built-in Dishwasher
Will not pump water out of dishwasher
The wash water will not evacuate from the sump. It will rinse and go through all of the cycles as normal except drain.
catriver
  • 878 Answers
SOURCE: The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
Wahmad, your safety device would be the float assy. First check your drain hose. If you have it going to a siphon break at the sink, these have a tendency to clog up. The drain pump is seperate from the wash motor. You can check to see if it's receiving voltage during the drain cycle with a meter. If you are showing voltage and no drain, there's your problem. Part number for the drain pump is 154407401. Catriver...post back.
Posted on Sep 26, 2006
  • 1073 Answers
SOURCE: Fridgidaire FDB126RBS2 Won't Drain in Rinse Cycle
check the drain pump for foreign object in the pump if nothing is found replace the pump
Posted on Apr 25, 2008
frcs68
  • 1605 Answers
SOURCE: Does not drain water after wash/rinse cycles
check the drain pump at the button of the dishwaher.
its not a big job, but it is a pain to take it out.
once you have it out, take a look of the bland on the motor, make sure they are all there, missing bland will cause the water to bunce back and nto drain completely. take a look of the motor, it should turn freely. the pump is oneway. make sure nothing else is broken from the pump and the outlet.
if all failed, replace the pump.
Posted on Oct 28, 2008
SOURCE: frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Posted on Mar 31, 2009
SOURCE: Dishwasher gets stuck on the rinse cycle right
Try turning off the high temp wash. I had a similar problem and found that the thermostat is bad. Turning off the high temp wash bypasses the high temp thermostat.
Posted on Jun 23, 2009
How to drain
The wash cycle starts with the pump running to drain residual water from the tub. Make sure your drain is clear before starting each cycle. I run my garbage disposal with water on for a few seconds before starting the DW. If I don't it won't drain properly with food waste in the disposer basket. You may also need to pull and rinse your drain sump screen (front right corner). Just snap it out and rinse. If your machine doesn't power up at all you'll need to use a sponge to drain the tub
Jul 07, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
Water pump evacuates water but does not pump in the wash or rinse
You assume correct. The control board switches the direction, but if there's a mechanical problem like a bad start capacitor, then it won't run
Jul 29, 2017 | Kelvinator MDB121RF Dishwasher
Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
My dishwasher is making a humming sound and does not rinse?
A humming sound can be a failing wash motor (that drives the water pump) or it can be as simple as a blockage in the the pump area beneath the lower spray arm, under the filter.
Remove the spray arm and the filter top (screws will need to be removed)
Use a flashlight and inspect all over the sump area for debris that is blocking/jamming the impeller area. Reasemble and test with a short cycle.
If the dishwasher continues to make the same humming, it is time to replace the wash pump.
Good Luck! Post back here if you would like more guidance.
Dec 08, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwasher hums loudly while running
if this hum is in the wash cycle then dissasemble the top of the pump assy and look for foreign objects in the pump
Apr 21, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Open Questions:
Frigidaire 24 in. GLDB957A - Multiple Color Energy Star® Built-in Dishwasher Logo
35 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
