Question about Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12
I have a 1996 Viking Motor Yacht with a Heart Interface Inverter Model 81-0253-12 (207) which I assume is a 1996 and I have been advised is not working. I would like to get an opinion on what my options should be concerning replaceing it or having it rebuilt. I have read on Xantrex website and it would appear that the Fredom SW 3000 would be a equivilent replacement but I can't determine what the one I have does. Bill
  • 33 Answers
I used Tekris when my inverter failed , Very professional ,reasonable and highly recommend them 18884835747 hope that HELPS
Posted on Nov 16, 2017
SOURCE: I have a Heart Interface Freedom 20
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Posted on Jul 04, 2009
  • 17 Answers
SOURCE: can't get my 84-2056-01 to work the inverter
This is over a year old, so presumably you solved your problem, but for reference for anyone else reading, the only connection between the inverter/charger and the remote panel is the RJ-11 phone type jack through which the remote panel also draws its power. Just make sure it is firmly seated (until it clicks) on both ends and that the wire is not crimped, cut, or chaffed in between. Otherwise, likely a defective remote panel.
Posted on Sep 27, 2010
SOURCE: I need a circuit diagram for a Heart Interface
hi im alwin the Q45 is JE200 while the Q47 is JE210,goodluck,
Posted on Dec 26, 2010
pctech1
  • 1940 Answers
SOURCE: I have Xantrex prosineStatpower 3.0 24v
Error Code 207 - Internal DC Bus voltage low.
  • Temprary condition caused by low battery voltage in conjunction with an overload condition.
  • Internal fault.
  1. Check if battery is OK (see error code 002).
  2. Disconnect AC and DC power to the PROsine. Reconnect DC and AC power after 15 minutes. If the problem persists, contact Statpower Customer Service.
  3. Contact Statpower.
Error Code 002 - Battery Voltage is too low.
  • Discharged battery.
  • Old or faulty battery.
  • Battery cables to the PROsine Inverter-Charger are too small, too long, or there is a loose connection.
  1. Charge battery.
  2. Check if battery can hold the charge by measuring the Voltage at the battery terminals when the battery discharging.
  3. Check cables.
If all else fails, maybe your battery has a dead cell, or worse. Try replacing the battery, or replace the inverter/charger.
Posted on May 18, 2011
motor1258
  • 6674 Answers
SOURCE: my heart interface freedom model
The other thing to consider is that auxiliary batteries need charge while sitting, plugged in, which can be accomplished other ways.
Posted on Sep 08, 2011
Good day, Have a Heart Interface 2000w model 81-0234-12 charger/inverter When connected to 12 v battery I get 275 v ac out from the inverter. Why not 220v ?
How are you measuring the output? The inverter makes alternating current and it can be measured wrong. Also it might be high if a regulator is bad and also if there is no load on the output..
Feb 06, 2015 | Heart Interface Boating
1996n buick regal 3.8 loss of power
Make the FixYa experience better for everyone by voting.
The possibilities are too numerous to list. My advise is that you drive to your nearest AutoZone and have them perform a FREE diagnostic scan.
All the best,
Ben
Nov 19, 2011 | Cars & Trucks
My heart interface freedom model 20 - blew up- what would be a good replacement or do i really need a inverter in my motorhome
Aug 05, 2011 | Xantrex Technology Heart Freedom 20 12...
I have a Heart Interface Freedom 20 inverter in a 95 American Dream, the inverter part number is 81-0209-12. It was subjected to a voltage surge by a runaway generator that lasted about 30 seconds. The...
Check with BR Wholsale, Marshall Mi or Marysville Marine, Marysville, MI they do some service work and may have additonal insight on how to resolve or find parts.
Jun 17, 2011 | Xantrex Technology Heart Freedom 20 12...
Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
Freedom 20 Inverter / Charger
1997 monoco dynasty and the invorter heart interface freedom model 20 the problem we are having is the we don't get any powere from the electric outlet and the lights don't work and there is a reading in side on wall that tells you about your electricity and it reads overload my # 817-614-7576 donna
Feb 16, 2009 | Xantrex Technology Heart Freedom 20 12...
Heart Interface link 1000 Manual??
Check the manufacturer web site:
Product Page:
http://www.xantrex.com/web/id/98/p/docs/pt/7/product.asp
User Guide:
http://www.xantrex.com/web/id/423/docserve.aspx
Feb 09, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12 Logo
111 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Tre Elkins
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
