Question about Intel Desktop Board DG41BI Essential Series Motherboard micro ATX iG41 LGA775 Socket SATA (735858212991)
I am getting beep codes on a new motherboard - Intel Desktop Board DG41BI Essential Series Motherboard micro ATX iG41 LGA775 Socket SATA (735858212991)
  • Elaine Albertson
    Elaine Albertson Dec 31, 2010
    What beep codes are you getting?
  • Intel Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 31, 2010
Pc beep code 1 long 9 short beeps = bios rom error
Your Motherboard is broken when the pc beep in that try to buy new one
Dec 03, 2013 | Gigabyte Core 2 Quad Intel X48 FSB 1600...
No video on asrock p4i45G motherboards
Hello the homepage is here:
http://www.asrock.com/mb/Intel/P4i65G/?cat=Manual
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
http://www.computerhope.com/issues/ch000996.htm
Beep codes:
http://www.computerhope.com/beep.htm
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Nov 26, 2012 | Asrock P4i65G Motherboard
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
Please help me to determine the problem of my PC, it has no output or display on the monitor, the processor fan is spinning when pluged and then will turn off after a minute, the power supply is ok because...
you may have to find a manual for your motherboard, which could be difficult if you dont know what kind it is. somewhere on the mnotherboard is a connection for a speaker. the motherboard speaker, which is probbably noit installed, is supposed to give out "beep codes" when you have fatal or serious errors related to booting. if you can get ahold of a cheap little speaker and figgure out how to hook it up to the motherboard, you will get a series of beeps,. once you have the beeps, you need to go to the motherboard manufacturer's website to decipher the beep code.
without the beep code, i can still confidently say-
the problem is prolly your video card or ram, and you ve already checked the ram. if you have an integrated video card, you might be able to disable the integrated card in bios and install a new video card, or you may have to get a new motherboard.
Oct 12, 2010 | Computers & Internet
Onboard video card not working. New card not either
please check Ram bcz its ram beep sound may be ram not attached in proper way that why sound come or may be its damaged
May 10, 2010 | ASUS M2NPV-VM Motherboard
GA-MA785GM-US2H
You can find the manual here at Gigabyte. The appendix lists this information about beep codes:
Hope this helps you figure out what to do next. Thanks for using Fixya!
Feb 20, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
Hp 7100 - replaced motherboard - still getting 5 beeps at POST At first I had an error code of 5 beeps - means processor. You can't replace the processor on this pc. So I purchased a motherboard. I am...
If you placed the same processor in the new motherboard then it would appear that the problem is following the old processor.
One common mistake with p4 cpus is the 2nd power supply to the motherboard. Make sure you have plugged it in. Its a small connector that is only required for pentium 4.
If not the above, you could check the bios settings for processor clock speed to make sure that you're not overclocking by too much. Also check the heatsink/fan. A processor will fail very quickly with inadequate cooling. If everything seems ok but still getting 5 beeps, try a new cpu or memory.
Oct 13, 2009 | Computers & Internet
1-5-1-1- beep code on Intel sds2 Mobo bought 2 new processors
I can find that beep code anywhere in the service manual which you can get here: Click Here
From what your saying though you may need to completely clean the surface and then reapply the thermal grease
Sep 07, 2009 | Intel Server Board SDS2 Motherboard
Abit beep code error and LED code of 87
Hi had similar problem today, 1 long 4 short beeps - so not exactly the same.
I ended up resetting the CMOS - and this fixed my problem.
Hope that helps!
Jun 06, 2009 | Abit AX8 Motherboard
Motherboard pc chips m810 lmr v7,1
The beep codes are not universal, but there are a few popular BIOS's and you can figure out what 2 beeps means if you can find your BIOS listed here:
The name of your BIOS should appear on the monitor as you're booting.
Nov 20, 2007 | Asrock M810LMR Motherboard
Intel Desktop Board DG41BI Essential Series  Motherboard  micro ATX  iG41  LGA775 Socket  SATA (735858212991) Logo
126 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
