Question about GE GSS25LGM Side by Side Refrigerator
Unable to get water out of the door dispenser
  • 472 Answers
Could be several items.... 1st you want to make sure you have a good filter in the unit if you havent changed in a while could be a problem... 2nd alot of the g.e. models have dual water valves and it could be the water valve solenoid is bad... if you have mechanical capability you can go to rear of unit and disconnect the line going to dispenser and hold a cup at valve and have someone depress the dispenser .... if you are getting water there that eliminates the valve and the actual dispenser switch ...if you are not getting nothing will need to test for 120 volts ac current and make sure the valve is getting power when you hit the dispenser lever. if no power the problem is going to ne the actual dispenser switch ... hope this helps service tech 18 years
Posted on Dec 31, 2010
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
I am unable to get water through the door when it is set for cold water. I installed a new filter and still I am unable to get water at the door. I can get ice or crushed ice.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
May 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Out of no where the water dispenser doesn't dispense water. Cannot figure out why it would do that. The ice maker works fine. We have had our Whirlpool refrigerator model #GI7FVCXWQ0 for almost a year...
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Oct 09, 2010 | Whirlpool Refrigerators
Water dispenser is not working
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 05, 2009 | Refrigerators
I want to remove the water dispenser from my LG Fridge GR-642AP
You must turn the water off, essentially disconnecting the refrigerator,(just to be safe as i am not there to do it for you),then you will be able to take it apart. remember to purge the water lines of air when reconnecting them.
Feb 01, 2009 | Zanussi Z57 / 3 Bottom Freezer...
Whirlpool Side by Side Water line cut at door hinge on bottom
you can try to take the inside of the refrigeerator door off and then replace the line or just quit using the feature. i would take the door off and take the inner panel off and replace.
Jan 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint hss25gfpe ww fridge with ice and water in the door. The ice works, but I am unable to get water. Why can I not get any water? The serial # is tf261776 if this is needed.
Most water dispensing fridges have a tank in the fridge to keep the water cold. If the fridge temp is too low it might freeze the tank and stop the water from dispensing. Also check the water filter to make sure it is not frozen. Water filters should be replaced every 6-12 months, if it's been longer than that it might be too full of dirt to allow water past. It also might be the water inlet valve is not opening.
Jul 20, 2008 | Hotpoint Refrigerators
GE GSS25LGM Side by Side Refrigerator Logo
79 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
