My Whirlpool model no: 6ALSQ8000JQI is not spinning the water out when finished
Our whirlpool wfs1285aw doesn't seem to be spinning and drying out clothes enough when Finished. The clothes are still drenched. Any ideas how to rectify this? Is there a filter that needs cleaning?
the rinse section spins slow while the rinsing is in process as this does 2 things
spreads the water through the clothes for a proper rinse
spins slow to equalize the cloths around the bowl
when the rinse cycle is finished and the tap is shut off it goes into a high speed spin
Your problem sounds like the program is not going to the high speed spin cycle and that would indicate a problem board
call a technician for a proper diagnosis and quote
Sep 15, 2016 | Whirlpool Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | GE WPRE6150HWT
My whirlpool machine does not spin properly and there is always water left after the spin cycle, when its turned on it will stop after spin cycle like its finished but there is still a lot of water left in...
hi, it sounds like one of two possibilties, will try and help out. The first thing to check is whether the water/drain pump is actually working fine, i think it blocked. Secondly the pump may also be overheating and malfunctioning during the cyle, run it without clothes and check the flow of the drain during the drain/spin cycle and take it from there.
Jun 14, 2011 | Whirlpool Washing Machines
I have a Whirlpool WTW57ESVWO that is acting up. It used to fill with water before the wash cycle started, now it starts together. Also, the spin cycle will be finishing and it will start filling with...
This sounds like a bad timer. This can occur if the unit is heavily used and/or it's over 5 years old. See this link for a parts breakdown (see part #9) under Controls.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5513874&diagram_id=28141944#d28141944
Disclaimer: I do not work for, have no affiliation with, nor represent this company. This is not the only place where this part can be purchased.
Jun 11, 2011 | Whirlpool WTW5700S
Washer starts agitation during water fill up and after spin cycle ends washer fills back with water and leaves clothes very wet.
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
Oct 20, 2010 | Whirlpool WTW5850S Top Load Washer
Washer will not finish its rinse or spin cycle
Check that water can drain out of the machine
1/ Check that the filter is not blocked
2/ Check drain motor is working (ie. not blocked with coins or hairpins etc)
3/ Check that pipe from tub to filter is not blocked (I had a sock blocking mine)
4/ If there is water in the filter and the drain motor runs then check that waste water hose is not blocked.
Aug 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Whirlpool washer
Since this question hasn't been updated in a while, I'm going to presume you corrected your problem? If not, feel free to message me back so I can get your model number and walk through other ideas with you.
Jun 26, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
