Question about Cosco 10-T58 Portable Crib
Broken lock? replaceable? - Cosco 10-T58 Portable Crib
    Guru:
  • 679 Answers
Sadly but no replaceable parts
Posted on Dec 31, 2010
Chevy cav door lock broken
You will have to remove the inner door panel
to replace it
You may want a repair shop to it ,or you can
You will need possibly the new lock keyed the same
by a lock smith shop before you install it
If your not talking about, or do not know the problem ,
then when the door is opened up, you may see other
issues such as linkage broken
Aug 03, 2012 | 1996 Chevrolet Cavalier
Vivitar 980 leg lock replacement
Who are these people designing the leg locks. These are the poorest examples of engineering. Even a child could see that the leg lock begs to be broken. Maybe Vivitar should stick to flashes
Apr 22, 2012 | Vivitar Photography
How to replace a broken needle in baby lock serger pro line modle BL450
I use a small screw driver to undo the screw, insert the needle all the way into the needle holder--flat side to the back of the machine, then tighten the screw back
Feb 21, 2012 | Baby Lock Sewing Machines
1999 porsche boxster; when opening drivers side door with key...lock mech spins free with no resistance and door doesnt open
It sounds like it could be the plastic connecting bit that links the lock tumbler lever to the rod that operates the door lock mechanism, has broken or become disconnected. To check, you will need to remove the trim on the inside of the door, after removing any screws and the inside door lever and window winder.
Once you have the inside trim off and the plastic sheet, you will see an access hole for the door mechanism and the lock tumbler. It should be attached to the actuating rod by the aforementioned plastic bit. If plastic bit appears OK try re-attaching it or replacing it if broken. If the lever part of the lock tumbler which attaches to the rod is broken the lock will need replacing.
Jan 10, 2011 | 1999 Porsche Boxster
Rear door lock on 2000 saturn broken. Stuck in
your gonna have to remove the inner dor panel and replace the latch lock assembly
Oct 12, 2009 | 2000 Saturn SC
Kenmore Elite Smartwash HE 4T
door lock issue ck for broken door strike on door broken door lock button on door frame also possible connection at main control under top at rear..if moving wires fixes problem try shimming in place only sure fix would be new control..lock not hard to replace remove spring holding door boot on and roll boot back 2 or 3 screws hold lock to frame remove and pull lock to opening remove wires and replace lock
Sep 08, 2008 | Washing Machines
Hatch back door on '95
yes, you can get a lock replacement for it, for a straight shoot, try getting it at the dealer as bad as this sounds.but will save you a lot of problems
May 20, 2008 | 1995 Volkswagen Golf
Cosco 10-T58 Portable Crib Logo
312 people viewed this question
Top Cosco Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
noel
noel
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
