Heater fires, runs for 10 sec, then shuts down. how do you fix this? frozen in wisconsin help
    Problem Solver:
  • 6 Answers
Check flame sensor or thermocoupler could also be gas valve
Posted on Jan 01, 2011
Heater wire fire up but will not stay running
that code signifies an ignition failure. as your system is propane, ensure that the pressure from tank is over 30psi. under that, the system may not run properly. check to be sure that all the shut off valves are in the right position. get a technician to bleed the lines. if the heater hasnt been run for a while, it is common for the LP to not flow properly. if the outside temperature is low, this will also affect how the propane works
Jun 20, 2014 | Hayward H Series Pool & Spa Heater 400k...
Reddish smoke
Sounds like it possibly may have frozen internally. Ice blockage and water was not circulating thru it, yet the ignitors fired and fired until it overheated and shut down. Possible that the exchangers may have been fried, that is why the funny color of smoke. Once weather is warmer and not frozen, run the pump with heater off and check for leaks. If no leaks in the heater and you can confirm water is circulating thru your system (water returning into pool thru the return lines) turn or fire up the heater and inspect/monitor its operation.
Dec 20, 2012 | Hayward H Series Pool & Spa Heater 400k...
I have a max e pool heater (400k)btu's,when I start the heater,the burners runs for about 20-30 sec.and then trips off,I have jumpered most saftey controls (temp) and have replaced the control mod. and...
You may have a problem with your air pressure switch. This is located in the exaust pipe I beleve. (not positive) But the heater will fire and if the draft is not right it will shut the heater down. Be sure that the heater is fireing not just the fan running.
Oct 04, 2009 | Sta Rite Sta - Rite Max - E - Therm Hd...
Maytag dryer starts for 30 sec.+thenshuts off with
sounds like the blower is not cooling the heater coil fast enough this will cause it to shut down to prevent fire
Jun 06, 2009 | Dryers
Heater won't refire after it warms up
CAD flame sensor is bad, 3$ part and easy to install.
Jan 22, 2009 | Reddy Heating & Cooling
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
