Question about Uniden Bearcat Pro PC68Elite 40-Channels Base CB Radio
GO TO A DEAD SHORT WHEN YOU PUT 13.VOLT TO RAIDO
    Problem Solver:
  • 44 Answers
Bad ground
Posted on Jan 03, 2011
  • Richard Dickinson
    Richard Dickinson Jan 13, 2011
    there is a diod inside the radio behind the transformer its black with a white stripe on one end it needs to be change out. you might be able to see it burned and that would be the one to change. and it needs to go back in the way you took it out or take it to a cb shop to fix it about $10.00 to fix it at a cb shop..
Battery keeps going dead
24 volts is way to high, the battery should be 12 volts, the alternator should put out 13 volts up to 15.5 volts, if the alternator belt is excessively loose, it wont charge properly, if the belt is tight check the alternator output, (you can ck it at the battery) make sure the output is a minium of 13 should be not less when reving the engine up a little the voltage should increase, but not above 15.5 volts
Apr 12, 2014 | Cars & Trucks
The car was running fine one day then the next day it would not start. We tried jumping it thinking the battery might be dead and it still would niot start. The car has power until we take the jumper...
Sounds like you have a toasted battery or alternator. Have you performed a load test on the battery? Have you tried to charge the battery? First remove the battery and charge it externally from the vehicle. If the battery won't hold a charge, or won't hold a charge of 12 volts, replace it. Once you have the vehicle started, test the operation of the alternator. It should be putting out at least 13 volts back to the battery to keep it charged - if it is putting less than 13 volts or more than 16 volts, replace the alternator.
Nov 01, 2011 | 2005 Chevrolet Malibu
I have a 2000 suzuki intruder 1500 lc, battery just went dead and turns over very slow and then dies, I just bought a new battery today and the went dead after riding for a few minutes, once again it turns...
Sounds like you have a bad stator or rectifier. If you like to work on your own bike get a repair manual it will give you several test you can do. Charge the battery to full charge, take a volt meter and put in on the battery leads pos to plus and neg to ground. start the bike and watch the meter it should be putting out over 13 volts if it is not have your rectifier and stator checked by a pro. also check the compression valve cable it may be out of adjustment . I had one of those bike for 13 years a great bike
Sep 17, 2011 | 2000 Suzuki VL 1500 Intruder LC
I have a 99 Pontiac grand am gt that has a good alternator that isn't charging the battery. The wires are connected correctly and the connections are clean and the battery terminals are clean as well....
Have you taken the battery to autozone or someplace and had the battery tested? I would find if you know the alternator is good it must be the battery itself. Might want to try that if you havent already. Good Luck Bro~
Dont forget to rate my answers~
Jun 08, 2011 | 1999 Pontiac Grand Am GT
The battery is good the alternator is good,but it is not getting enough volts to recharge the battery.
if the battery has a dead cell or two it will not charge all the way,,if the alternator is not putting out 13 to 14 volts its not charging at full..
Apr 03, 2011 | 1998 Chrysler Town & Country
The battery went dead when I tryed to start in cold weather,I removed the battery and charged it back up, However when I put the battery back in the car started and ran for about five minutes when it shut...
You have a dead short across that fuse, The end opposite the battery will probably show a ground rather than a resistive load. You are going to have to find that short and fix it. A dead short on a 60 Amp fuse is a heavy load. That fuse is probably preventing a fire or melted harness wires.
Jan 25, 2011 | 1991 Honda Civic
How do you know if your alternator is going bad? and how do you know its not something else draining the car? like an after market raido it was instaled with a speed wire harness but i am getting a wierd...
An alternator going bad will drain your battery in a few hours of driving, and it will not recover. A battery going bad might give some trouble starting the car, but once under way, it will recharge, and work for many weeks until it finally dies. A bad connection on the 2 power cables to radio (ignition & live battery) will trip the corresponding fuse, so that is not the problem. You might have bad speaker connections, and it will sound like you describe, but it will NOT drain the battery. My best advice is 1) Disconnect the radio for a day or so, and see if the condition improves. 2) With a voltmeter, test the battery voltage just after shutting down the car. It should read 13-14 volts. Then test it one hour after that, and it should read 12-13 volts. Should voltage read below 12, then you have either an accessory draining the battery, or a short circuit.
Jan 22, 2010 | Chevrolet Monte Carlo Cars & Trucks
I had put a brand new battery in the car twice and it dead in less then a week change the battery post and every thang
Locate the large red wire coming off the back of the alternator, with the car running with the lights on, heater fan on high and radio on use a voltmeter touch the red probe to the red power wire as you touch the other black probe to a bracket or suitable ground the reading should be 13 -14 volts if it is below 13 volts the alternator is bad replace it. If the voltage is ok there is a closed circuit or short circuit somewhere. Something is using power with the key off.
Jan 21, 2010 | 1994 Mazda 929
Red light keeps comming on and battery goes dead.
Alternator and stator....put a voltmeter on the battery - it should read about 12- 13 volts. Then start the bike.... when its running, the volts should increase.... if it doesnt....your charging system isnt working.
Jun 27, 2009 | 2006 Harley Davidson XL 1200 R Sporster...
Car goes Dead
Normal charging volts are about 14.5, 13 volts is too low. The spec from Ford is 14.1 to 14.7. Broken wires or a bad connection are common.,
Jan 27, 2009 | 1998 Ford Contour
Uniden Bearcat Pro PC68Elite 40-Channels Base CB Radio Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
