Question about Iomega Portable Hi-Speed USB 2.0 40GB, Silver Series 40 GB Hard Drive
Iomega portable Drive LPHD160U
This drive when connected to my PC will work for a few minutes and then drop out. If I leave it connected it often comes back and remains working again for a few minutes, but will not stay connected to allow me to load and download files.
Can you help ? My system is XP and I have no problem using flash drives with my PC just this portable drive.
My email address is cyril.halstead@care4free.net My telephone 020 8363 7867. Since buying this drive I have been unable to us it with my PC
Cyril Halstead
  • 2 more comments
  • Anonymous Jan 05, 2009
    same problem. i'm looking for the drivers. It will solve the problem
  • Anonymous Jan 21, 2009
    I still have the same mproblem as listed above last July 08, no one has been able to come up with an answer. I have had to give up trying to use my 160 BG Hard Drive on this computer and can onlyt use it with my laptop and works PC
  • fakpovo2 Feb 06, 2009
    The same problem I have with the 160GB one.
    It is a shame for that product. I saved files on it and since summer 2008, I can't access my files. On IOMEGA websearch, the drive was not found.
    Cicoben
  • icabuck2 Mar 02, 2009
    Same problem. I've done everything I can think of.
Use external power supply !!!
Posted on Jan 21, 2009
MATCHING CABLES FOR A IOMEGA LPHD-UPC
Use a USB 3 cable it will provide more usb throughput
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
Jan 24, 2013 | Iomega 500GB Prestige USB 2.0 Portable...
Windows 7 driver for160GB eGo USB 2.0 Portable Hard Drive?
According to the Iomega Support web site you do not need additional drivers for using your Iomega eGo drive with Windows 7 unless you have a USB 3.0 device.
See this Iomega document on what you should do if your drive is not detected on Windows 7
Jan 14, 2012 | Iomega 33914 Storage 160gb Ego Silver...
Hi, I have dropped my iOmega portable HDD. The actual drive inside the iOmega case is a Samsung 1TB HM100UI. Now when connecting power to the drive I get a sequence of beeps/sounds then nothing. The...
If you remove the drive and connect it to a pc using the sata cables it could work if you only damaged the controler.
In my experience it is more likely the drive itself is damaged. If this happens and the read/write head or the magnetic store is physically damagedthe only way is to ask a data recovery company. The good news is that recovering a single drive is relatively cheap......
May 19, 2011 | Samsung Spinpoint MT2 HM100UI 1TB SATA...
Reformat to FAT32
If you are using windows.
You can right click and when the format dialog box opens look for the drop down arrow that is labeled file system. make sure it says fat32. and then format the drive
Mar 23, 2011 | Iomega 250GB Ego Portable HD Red 250 GB...
Hi, I was given an Iomega portable hard drive but I don't know how to get started using it. Can you give me a brief introduction on what to do? Thanks, Bev Brink
All that you should have to so is plug it up to your computer with the USB cable. Somewhere between a few seconds and a minute (for the first time), it will pop up under my computer. So double click on "My Computer" and you should see it listed as one of the drives. You might actually see a picture of the drive! I hope this helps!
Mar 02, 2011 | Iomega eGo Portable Hard drive 500 GB ...
My Iomega eGo Portable Hard drive 500 GB main light is not showing when i plug it in through the usb drive, i think this connection may be damaged. Is a way to solve it to buy dc5v to usb cable and plug it...
Have you tried connecting it with the Firewire cable that came with it? (your pc may not have the correct port) or connecting it with a different usb cable?
Has the drive been dropped? it has a protection system which shuts the drive down when it is dropped. you may need to put the HDD into a different caddy or plug it directly into a desktop pc's motherboard to retrieve you data.
I hope this helps.
Jan 21, 2011 | Iomega eGo Portable Hard drive 500 GB ...
Transfering photos to my Iomega Prestige 500GB Portable Hard Driv
Does the Iomega show up under 'my computer'?
It should be another drive (D, E, F whatever) and as such you put stuff on to it the same way you would put stuff on to your C drive.
Mar 16, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Iomega 320 portable drive connection problem
sounds like a defective drive. maybe it took a bump in shipping?
take it back right away.
Sep 10, 2009 | Iomega (33576) 320 GB USB 2.0 Hard Drive
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Portable Hard Drive refuses to stay linked with PC
I'm thinking the usb port being used on the home pc may be bad. Do you have any others available to use?
Jul 06, 2008 | Iomega (32453) External ZIP Drive
Iomega Portable Hi-Speed USB 2.0 40GB, Silver Series 40 GB Hard Drive Logo
2,770 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
