Question about Gateway 506GR PC Desktop
Loud noise Hi. I'm hearing a loud noise coming from the tower of my Gateway 506GR tower this morning. I'm assuming it's the fan, which is a lot louder than normal. It sounds like it's just running really loud.
    Scholar:
  • 66 Answers
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Posted on Jul 08, 2008
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
Dell dimension 4700: top fan makes a lot of
some fans are just loud, they tend to speed up and get louder when the computer heats up, it keeps it from over heating... if it always runs hard and loud the internal thermostat could not be working right.
Feb 23, 2010 | Computers & Internet
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Loud gateway 5310 desktop
its your power supply that making nosies, change it to a quiet one. or its you processor fan. if so you need to clean it from dust. also clean your power supply and if you are lucky the noises disappears.
Oct 12, 2009 | Gateway 5310S PC Desktop
Thumping noise while running
sounds like the bearings are bad or something is catch in the fan
Apr 03, 2009 | GE Zoneline AZ55H09D Air Conditioner
Dell 3000 PC is extremely loud like a vacumn cleaner right next to your ear... and gets louder and louder throughout the day. Have ran disk clean, Registry Mechanic, and Disk Defrag. Lots of room left on...
Check your cpu fan, chassis fan, and the fan on the power supply. If all the fans are working then the bearings in the hard drive is about to go out. That is if you are not using a cd or dvd rom.
Mar 05, 2009 | Dell Dimension 3000 PC Desktop
I replacement fan
They sell some things that you can put on the fan so it can run quietly without making any noise.
Oct 28, 2008 | Gateway 506GR PC Desktop
PC Fan Issues
1 fan in and 1 fan out, usually out through the front.
Aug 27, 2008 | Gateway 506GR PC Desktop
Gateway 506GR PC Desktop Logo
1,193 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
