Question about Frigidaire 24" Built-In Single Gas Wall Oven - Black
My frigidaire oven was cleaning itself and now it wont open
My mother's 2nd wall oven (in less than 4 years) is having the same problem. I posted on Frigidaire's facebook page and they removed my negative reviews. It seems that EVERYONE with this gas wall oven has this problem. Two repairmen could not fix it (but charged over $200. It seems this oven has been this way since 2007. Shameless that Frigidaire would manufacture such trash. I'm so sorry--we don't really have other options because no one else seems to make an oven to fit those specs
Posted on Jan 04, 2011
Frigidaire Oven door wont open after self clean cool down
Good Morning Marlyn Allen, thanks for your post!
Based off the information you have provided your Frigidaire oven door will not open after it has cooled down. I would hold down the clear or cancel button for ten seconds that should release the door. If that does not work I would perform a reset on your oven and you can do that by disconnecting the power from it for approximately ten minutes. You can also perform another self-cleaning cycle and before it starts cancel the self-cleaning and then wait for ten seconds and the door should release. If you follow these steps and the door does not open it could be a faulty door latch and that would need to be replaced by a technician. Best of luck! -Matt
Dec 12, 2014 | Frigidaire Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire electric wall oven wont open error code f90
    Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
    Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
    I have a frigidaire Electrolux self cleaning convection oven. I put it on self clean and it went fo over ten hours. now the door is locked and I cant open it. I tried to self clean and it wont start. The...
    These ovens have notoriously bad control panel electronics. There is one control board for the oven that can be replaced or sent out for repair, $100 to $300.
    Feb 03, 2018 | Frigidaire Ovens
    Self cleaning oven sparking and wont unlock
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Apr 11, 2010 | Frigidaire FEB27T5A Electric Double Oven
    Oven wont work
    If the sensor were bad, the unit would throw a fault code. On the back of the range, near the top, there should be a tech sheet for you to use to troubleshoot the range. It sounds like a thermal sensor may have opened up. Consult that tech sheet, it should point you in the right direction.
    Dec 12, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Lost manual to my electric oven, how do you clean inside of oven?
    Make shure every thing is out of the oven, and that the door is well locked, then hit the cleaning button.
    the oven will clean itself with high temperatures.
    HEre is a manual for a frigider oven, should be not too different from yours.
    Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven locked so I can't shut door/operate oven
    Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
    Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire 24" Built-In Single Gas Wall Oven - Black Logo
    196 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
