Question about Master Lock 5400d: Portable Select Access Key Storage Lock
How do I reset the combination? - Master Lock 5400d: Portable Select Access Key Storage Lock
  • 56 Answers
Open the lock with the existing combination. Inside the outer panel, you will see a small lever that will push to the right, and **** in an upward position. With the lever cocked in this "learn" position, turn each wheel to line up the number you desire with the scribed line. Once all four wheels are parked on your chosen combination, flip the lever back into its "home" positon. Test the new combination a few times (and record it somewhere safe), before you close the lock up.
Posted on Jan 05, 2011
Set combination lock
Step 1:
Locate the reset button, usually placed to the side of the combination dials.
Step 2:
Press the reset button and hold it while rotating the number dials to the desired combination.
Step 3:
Release the reset button after you set the numbers to the new combination.
Try that :)
Jan 23, 2015 | Samsonite Leather Expandable Briefcase -...
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
How do you reset the combination to a Ace Solid Brass Combination Padlocks
Open the lock, rotate the shackle180 deg, and push down.enter new combo, and rotate shackle back to normal position.
Mar 27, 2014 | Ace Hardware Ace Solid Brass Combination...
How do you unlock a TSA COMBINATION LOCK WITH fogotten. number?
The only way to reset a TSA Combination lock is to turn the numbers until you get it. The good news is that you only have 1000 possible combinations. Start at 0 0 0, then 0 0 1, 0 0 2, etc...
There are posted videos on YouTube that talk about how to reset locks with unknown combinations but they are specific to the brand of the lock; assuming they aren't fake videos anyhow.
Nov 19, 2013 | Home Security
Unlock pacsafe 100 have forgotten code
Instructions are included with every combination lock, however if you have lost them, please refer to our instructions which can be downloaded at the respective product page. If you have set the combination once, you will need to remember this combination when resetting again (i.e. replace the 0-0-0 in the instructions with the combination you chose).
Apr 09, 2013 | Pacsafe Daysafe 100 Travel Backpack in...
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
Note: Using excessive force can damage the dials.
Step 3. Set the new combination while maintaining the position of the "RESET" dial.
Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
Sep 07, 2010 | GE Home Security
How to set Samsonite combination lock
Step 1:
Step 2:
Step 3:
Try that :)
Sep 26, 2009 | Kwikset Locks & Locksmithing
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
factory to 0-0-0-0
(see instructions above)
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
288 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
