Question about Hotpoint Refrigerators
I have a Hotpoint CTF21E refrigerator, the ice make is not working, seems that water is not being delivered to the freezer. I suspect the solenoid valve is not operating perhaps because it is not seeing the electrical signal to energize. Where can I get an electrical wiring diagram for the refrigerator or do you have any suggestions what I should look for when troubleshooting.
icansurf
  • 72 Answers
SOURCE: ice maker leaking water after replacing the solenoid valve two times
maybe the solenoid stays on too long during the fill cycle.. broken gear maybe or out of adjustment
Posted on Jul 11, 2007
SOURCE: Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
Posted on Sep 01, 2007
watugot
  • 290 Answers
SOURCE: amana scd25tw
It sounds like you have covered all the primary troubleshooting checks. There is only one thing I can think of at this point.
Check the voltage coming to the water valve during the icemaker cycle. The power to the valve is decreased by the resistence of the icemaker heater from 120 volts down to about 108 volts. It is not uncommon to have a valve that will open when you put 120 volts to it, as you do when you switch solenoids, but not open at the decreased voltage when it goes through the icemaker circuit.
If you are getting voltage to the valve when it cycles, and you know for sure the water line to the icemaker is clear, then you will need to replace the valve.
Post back and let me know what you find.
Posted on Nov 11, 2007
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
TampaNative
  • 778 Answers
SOURCE: Ice maker not working
It's possible that the tube that supplies water to the ice maker is blocked with ice (freezer temp. too cold) and not allowing water to get to the Ice tray.
You can squeeze the tube to see if it's iced, and if so you can melt the ice with a blow dryer and adjust your freezer temp. to the manufacturer's suggested setting and work from there.
I have seen this happen, but there are other problems such as just a broken ice maker too.
Good luck.
Posted on Feb 27, 2008
Not making ice
For ice maker to work make sure freezer temp is at least 10 degrees or less. Check for water in tray - if no water suspect water solenoid, if ice in tray check heater circuit for ice cube removal.
Jul 24, 2015 | Refrigerators
I have a Jenn-Air refrigerator #JCD2389DES. The ice maker became stuck and kept delivering ice cubes even after dispenser was released. I finally opened the freezer door and got it stopped. Now it...
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Jun 16, 2011 | Jenn-Air JCD2295HES Side by Side...
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Icemaker making small amount of ice
I RESET THE SWITCH ON THE ICE MAKER AND TURNED THE TEMP TO 9 FROM 5 AND IT STARTED MAKING MORE ICE. I'M NOT SURE WHAT WAS WRONG BUT IT APPEARS TO WORKING FINE NOW.
Dec 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
