Question about 7701V Responder 2way Transmitter LCD Paging Remote Transmitter
My remote and truck did make a beeping sound when locked and unlocked and all the sudden all noises quit kind of like everything is muted. How do i fix this?
I have 5.5clifford remote start /seurity two way sec remote not working after parked for winter both twoway may need pairing?
Posted on May 03, 2011
When I press the unlock button, why doesn't the horn beep?
I have a 09 kia spectra, The only time the horn will honk. is when I lock the doors with the remote. Unlocking just makes the lights flash! God-Bless! and hope this helps you out.
Mar 14, 2016 | 2013 Nissan Rogue
How do i get my tablet screento rotate
What type of tablet? If it's an iPad this is available a few different ways.
If it's an iPad 1 running on iOS5:
1. Check the little toggle switch on the side, depending on your settings this functions as both a mute and a rotation lock. Try changing this.
2. If your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Double click the home button and when the little menu pops up swipe right on it, you should see an option to lock/unlock the rotation.
If you are on a newer iPad
2. f your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Swipe up from the bottom of the screen to access the control panel. The screen lock/unlock option is directly on the control panel.
Dec 11, 2014 | Tablets & eReaders
Performance Teknique Icbm-7071 Everything on my alarm system is working, but now the only thing that will not work is the alarm sounding off. My receiver still beeps when my alarm goes off, but the car...
Sound like the siren. check the connections at the siren. If the connections are good and the system is sending a signal then, you may need to replace it.
Jul 27, 2012 | Car Audio & Video
Hello, so I'm 20 years old and have recently bought a 2004 Toyota Camry LE from my grandmother because she recently just bought a new car. Car works great, has less than 50K miles on it, never were any...
sounds like the alarm sensors are quite sensitive and r picking up air vibrations or could b a cat climbing on the car u should be able 2 get the alarm ajusted
Sep 08, 2011 | 2004 Toyota Camry
I've justreplced a new battery for my 2006 Audi A4. Everything is working fine, but whenever I use the key to lock my car, there is no "beep" sound and no light flashing indicating the alarm system is on....
unlock/hold key over for 30 secs ,windows will go down,then lock the car with key/hold over for 30 secs,windows will go up.then prees/hold down unlock button on remote for 30 secs,you have just reset the alarm/immobiliser.
Aug 25, 2010 | Audi Cabriolet Cars & Trucks
Hi...we just replaced the battery in my 99 Toyota 4runner Limited. Now when I use the remote key to unlock or lock the vehicle it no longer makes the beep horn sound. The remote itself still works to lock...
The aftermarket remote starter probably reset. Do you have the instruction manual for it? You should be able to run it through the initial 'start up' options and set the horn to beep for you.
Jul 25, 2010 | 1999 Toyota 4Runner
Suddenly I am not able to use my keyless entry. Also the door is making the dinging noise when the key is out of the ignition and the door is open. Everything else seems to be in working order and I just...
try this...put key in drivers door and turn to lock car,hold over for 30 seconds then release to neutral position.then press and hold remote unlock button down for 30 seconds.then lock with remote as usual.
this is the reset mode for the central locking.
the dinging noise normally indicates that an interior light is on or that you have left the indicators/turn swich to on.when you do, either left or right side parking lights come on (wiring on car is universally used)
Feb 11, 2010 | 2007 Hyundai Tucson Limited
95 Toyota Camery, The car remote locks and unlocks, the security led flashes when set, the locking and unlocking beeps and alarm sounds are now gone. Whole system replace or is it the loud speaker unit...
if the light is flashing and the central locking works then its all good the speaker wire has maybe broken inside plastic casing but hey if it all works with out the noise then leave it
Jul 19, 2009 | 1995 Toyota Camry
04 Chevy Malibu won't unlock
Remote control door lock reciver an the BCM - body control module control the locks . The key switch is a electrical input to the BCM , the BCM controls the door lock actuators . Your best bet ,have it towed to the dealer .
Jun 18, 2017 | 2004 Chevrolet Malibu
7701V  Responder 2way Transmitter LCD Paging Remote Transmitter Logo
134 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
