Question about Sony Cyber-Shot DSC-P32 Digital Camera
When i take pics the zoom lens doesn't come out
  • Sony Master
  • 890 Answers
Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Posted on Dec 31, 2010
My canon rebel t3i will not take pictures when zoomed in using the 18-55mm lens. it will only take pics when fully zoomed out
Does it work OK with another lens? If so, problem is in lens. If not, then problem is in body. I would suspect the lens
Feb 27, 2013 | Canon Cameras
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
Hello please help in live view mode when i press the button to zoom 0x/5x/10/ the pic is very close in my LCD screen.my question is that when i am at 5x or 10x when i want to see my pics i have taken in...
The zoom button merely zooms in on the display. It magnifies a portion of the picture so you can get a better look at what you're about to photograph. LiveView or otherwise, if you want to zoom, you have use the zoom ring on your lens (assuming you're using a zoom lens in the first place, of course).
Nov 07, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Lens stuck. Could not power on.
i want to delete pics from the memory disc in on my camera it's a olympus digital camera c-920 zoom
Dec 07, 2009 | Olympus Camedia C-740 Ultra Zoom Digital...
Zoom won't go in or out canon power shot sd870
zoom will not work in movei mode.
operate zoom before shooting in movei mode.
Apr 09, 2008 | Cameras
Action pics with a long lens
What you are experiencing is not blur, its camera shake. You are shooting in low light so the shutter speed is being reduced by the camera's automatic features. Also the longer the lens (the farther you zoom), the higher the shutter speed you need. Even for non moving objects or when panning the shutter speed should be at least one stop above the focal length. ie - 300mm lens = 500 or 1000 shutter AT LEAST! (and don't forget, if its a film lens on your rebel, thats actually 300mm x 1.6 =480mm, so 1000 shutter or higher min.) Moving objects require even faster shutters. Solutions: Get faster (also called brighter) lenses which can be pricey. In low light use higher iso settings in the camera menu. Shoot in either manual or Tv mode and choose the higher shutter speeds while using the light meter to decide aperture. Use wider angle lenses or back off the zoom and move closer. Stabilizers built into the lens can steady the shot by two to four times as well.
Sep 14, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
I need to know how to remove the zoom lens to clean a water spot inside.
well u can, but u will need to know what are u doing, i repaired many lens when i worked in olympus, but gives lots of work.
Dec 14, 2006 | Olympus Camedia C-5500/C-55 Sports Zoom...
Sony Cyber-Shot DSC-P32 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
