Dishwashers Logo
Anonymous Posted on Dec 31, 2010
We've had the dishwasher for 2.5 years without trouble until recently when the dishes and utensils now come out with residual white film (soap?). I tried cleaning the filters and checking that the nozzles are clear but the problem persists. Any idea on what else to check?
  • 4 more comments
  • Anonymous Dec 31, 2010
    Spray nozzles are fine and the dishes are hot at end of cycle so it doesn't seem like those are the source of the issue. Anybody familiar with this Bosch model?
  • Anonymous Jan 03, 2011
    The vinegar cleansing solution did not work. AnyBoschexperts out there?
    Hi Macmarkus,
    Model number is SHX55M05UC / 50
    Not sure if this is the serial number: SN11X5B. 10802008487400316 6
    Thanks
    Not all of the images came through. Can you e-mail me at:
    [email protected]
    Thanks!
    Hi
    No luck on the embedded images. Can you e- mail me the info at [email protected]?
    Thanks!
    No luck on the embedded images. Can you e-mail me the info at [email protected]?
    Thanks!
Anonymous
Level 3:
  • Dishwashers Master 2,605 Answers
  • Posted on Jan 03, 2011
Anonymous
Dishwashers Master
Level 3:
Answers
2605
Questions
0
Helped
1119429
Points
11111
Hi, Welcome to FixYa. Could you provide a model number and serial number please. They are located on the outer door panel to you right...when facing front of unit. Let me know what you find. I'll watch for your reply and help asap. Regards, Macmarkus :)
  • 5 more comments
    Hello again,
    Thank you for providing this info, it is actually quite important to assuring we have the right model since Bosch has gone through alot of changes in the past 10-15 years...as far as controls, features etc.
    I think the logical place to start is to perform a diagnostic to determine if any components themselves are at fault, then move forward based on the results. Based on the issue you posted the cause can be several things so it's best to start here.
    We can do this in a couple of ways, I will first post the procedure here, then if you'd like I can send you the service manual via email if you want to post your email address, it's your call.
    To enter a diagnostic is as follows...( this includes your model SHX55M despite it not being listed, same as SHX33A&43E )
    Once diagnostic is completed ( typically slightly greater than 20mins at water inlet temp. of 120F...since it must reach 150F for test and Bosch heat at rate of 2F per minute ) you'll either be presented with an error code, or not. This is what to look for...
    For models with no display...
    Let me know what you find from this and we can move forward from here, knowing what to look for specifically.
    i'll watch for your response.
    Regards,
    Macmarkus :)
    Sorry to see those got cut short for whatever reason. This is how they should appear...
    ERRORS FOR UNITS WITH NO DISPLAY...
    Macmarkus :)
    ERRORS FOR UNITS WITHOUT DISPLAY...
    Not sure why this is so troublesome, I do it all the time ?
    Hello again,
    That doesn't seem to be working so I'm going to try something different, but follow my initial post for reference.
    **To enter
    SHV46C, SL84A, SHX33A/43E/ 46A-B test programs, hold down buttons above (2nd & 3rd from left of three test program buttons), then turn dishwasher on by pushing on/offbutton.
    When in test program, 2ndbutton light (Regular Wash) will be lit and 3rdbutton light wil flash.
    Push 2ndbutton (Regular Wash) to scroll until test program is chosen, when 3rdbutton light is lit p
    ush 3rdbutton to start test program.
    Allow program to finish to sefault codes. Push 2ndbutton (Regular Wash) to skip certain steps. Turn dishwasher off to exit test program.**
    Once complete the unit will display these type of errors if any are found...
    0 - No faults
    1 - Aqua Sensor (Sensotronic) fault
    2 - Heating system fault (heater, Hi-Limit, flow switch, NTC, control heater relay)
    4 - Water filling fault
    8 - NTC (temperature sensor) fault
    16- Water switch fault
    **TIP: Fault codes add up for multiple faults (e.g. heating + water filling fault = 2 + 4 = 6)
    Hope fully this post will show up as I intended it to this time.
    Macmarkus :)
    **To enter SHV46C, SL84A, SHX33A/43E/ 46A-B test programs, hold down buttons above (2nd & 3rd from left of three test program buttons), then turn dishwasher on by pushing on/offbutton.
    0 - No faults
    Macmarkus :)
    Service manual on its way via email attachment..."pdf".
    Tried to send it about 20mins ago. Perhaps you're email has blocked it due to attachment since it came back as undeliverable. It is only about 3MB in size, I'll try again.
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Jan 01, 2011
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801240
Points
33142
Hello steph..... Pour 2 cups of vinegar into the empty dishwasher and then run your hottest and longest cycle [pot scrubber if u have it]. Also, always run the hot water into the kitchen sink until it is as hot as it gets before starting the dishwasher. The vinegar will thoroughly cleanse the machine. Repeat this cleaning on an as needed basis.
Also, reduce the amount of soap you are using by about 1/3rd. Joe
Thanks for choosing Fixya!
Anonymous
Level 3:
  • Dishwashers Master 43,501 Answers
  • Posted on Dec 31, 2010
Anonymous
Dishwashers Master
Level 3:
Answers
43501
Questions
0
Helped
10842655
Points
101584
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Leaves a white soap residue over the dishes, the dishes are scratched. New Kitchen Aid model KUDS50FVSS4 just purchased one month ago and it's performance was not as good as my old ( 15 years) GE. I have...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;'
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
heatman101//
All of a sudden my dishwasher is leaving a white powdery film on the dishes and really bad on the utensils. It had been working beautifully. Is there something inside that might be clogged that I should...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
GE TRITON dish washer. Utensils are stained after wash. I tried all that suggested solutions like cleaning with white vinegar, make sure hot water flows before it starts. I donot think we have hard water...
heatman101
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
heatman101
l'l
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
heatman101
Residue on dishes Dish washer is maytag Dwy 7402 aab purchase in 1996 Soap residue, cleaned top spray arm, but cannot get the bottom off, is there a trick to it without breaking the plastic
heatman101
Model # GLDA690MBB is only 2 - 2 1/2 years old, and only recently I've noticed a white chalky residue left on everything after it's finished. I 've always used the cheapest detergent and never had a...
heatman101
l'';
Leaves baked soap scum on utensils
heatman101
Soap stains on dishes
heatman101
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
