Question about Vinotheque Whisperkool 3000 Wine Cooling Unit (Max Room Size = 650 cu ft)
Freezes up after running just a few hours - Vinotheque Whisperkool 3000 Wine Cooling Unit (Max Room Size = 650 cu ft)
Why does my central air keep freezing up?
An air conditioner freezing up is either low airflow or low on refrigerant. If the filter is clean, then check the refrigerant level, blower running at proper speed, make sure indoor coil is not dirty or restricted. Make sure that the duct outlets are all open and some have not been closed.
Sep 01, 2014 | Heating & Cooling
Freezer alarm goes off after runnung for a few hours
Can't be specific without seeing it. All alarms I have ever seen have adjustable set points and differentials. It looks like a commercial box? Look the controls over real well and you should find it. You may need to remove a cover for access.
Dec 07, 2013 | Frigidaire Freezers
Why does my Dell Inspiron 530 freezes up after being on for a few hours?
Check your battery status. It is possibly overheating whitin time and causing malfunction.
Oct 25, 2012 | Dell Inspiron 530 Desktop Computer
MSI K9N6SGM-V (MS-7309) freezes when running 64 bits OS (operating systems) both windows or linux
You could definitely try updating your Bios to the latest version. Which you can download from here:
http://www.msi.com/service/download/bios-10230.html
Make sure you have installed all the drivers installed, especially the chipset drivers.
Personally though if it isn't a Bios problem then I suspect that at least one of your capacitors on the motherboard is going out. It appears to have the old style capacitors installed which were less durable than most made for today's motherboards.
The fact that it freezes after a few hours really make me think capacitor problem or a memory leak.
May 29, 2012 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Freezes almost everyday .wont even turn off.always have to let battery run out then restart next day
When the computer freezes, you can remove the battery physically instead of having to wait the few hours for it to run down. Underneath the laptop are two tabs holding the battery in, just release them and pull it out.
Are you using the machine on a soft surface (bed, couch?) that would allow it to overheat and malfunction when it freezes? Are you overloading the CPU with too many overbearing programs? Perhaps you've got a virus?
You'll need to be more specific about what you are doing when the freezing occurs. This could be anything ranging from software to hardware faults.
May 11, 2011 | Acer Aspire One PC Notebook
My D400 overheats and screen freezes when hooked
The biggest issue docking is airflow. With the system docked, airflow is restricted.
Might look at ways of improving airflow.
May 25, 2010 | Dell Latitude D400 Notebook
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
Freezing after few hours.
is the filter clean? If not then the fan cannot draw air thru the coils to exhaust moisture.. and will build up and freeze ..
Aug 22, 2008 | LG L1204R Air Conditioner
Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 01, 2006 | Creative Labs Zen Micro MP3 Player
Refrigerators Logo
24 people viewed this question
Top Vinotheque Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Vinotheque Refrigerator Expert? Answer questions, earn points and help others
