Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY Trinatron 27" Gets No Reception
I'm still using rabbit ears (I know, I'm in the dark ages) and they stopped working. I get a "No Signal" message on the TV. The rabbit ears work with my other TV - I hooked it up exactly the same way in the same location. My Sony works great to play DVD's. Any ideas on what to do?
  • 58 Answers
Hello
What are you using to connect the rabbit ears to the tv, a 300 to 75 ohm plug assembly? it may have sprung the contacts in the rf socket of the tuner.
or The tuner has malfunctioned,
It may be switched to the wrong source as some tvs have more than one tuner input.
Thanks Guy9
Posted on Jul 12, 2008
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
No signal on set top box im using rabbit ears and
The problem is that rabbit ears aren't that sensitive. They don't pick up enough signal quality before the amplifier stage to get decent reception. They only work well if you're in a location where the signal strength is very high.
There are some general tips for using these indoor antenna/aerials such as getting close to a window. But if you live in a building constructed from the mid 80's onwards then there's a good chance it has foil-lined in-wall insulation which is great at blocking external TV and radio signals.
If you can get an external aerial put up then do that. Alternatively, can you tap in to someone elses external aerial feed? (With their permission, of course).
Sep 08, 2014 | Televison & Video
Antenna
Really tough to get perfect reception with Rabbit ears. If you can somehow feed the line outside a lot of the times I have found that it helps improve signal reception
Jan 25, 2013 | RCA Ant121 Indoor Passive Antenna
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
TV picture freezing
digital signals do not fade out and get snowy like signals used to do ... if the signal gets too weak then it just freezes .. you might say its either perfect or frozen .. sometimes it gets blocky .. where some sections of the screen freeze while other sections continue .. what that means if you are using an antenna is .. you need a better antenna or better aim for the one you have .. outside is much better than inside but just rabbit ears are ok for strong signal areas .. you can aim the antenna based on a signal strength meter usually provided in HD receivers in the setup menu .. you can also get an antenna map from "www.antennaweb.org" .. that will show you what direction to point the thing for each channel and how strong each channel should be ... if you are using Cable instead of an antenna then you should have good signal strength but there is a problem called "Crest Factor" .. that becomes an issue when they put too many signals on a given cable .. the cable handles it ok as long as there is no damage (bad ends, water inside, animal chews, corrosion) but the cable box or receiver may be overloaded as thousands of signals drift in and out of phase ... thats a cable company problem that might be getting worse as more channels are added .. the results are that periodically the picture will freeze or pixelate .. you probably have to accept a little of that but more than a little gets really irritating ....off the air reception with an inside antenna (like rabbit ears) you will find that moving around the room can effect the signal for channels in the UHF range (most are) .. aiming the antenna and getting it as high as possible will minimize that problem.. make sure whatever antenna you use is designed for UHF as well as VHF .. the little circle often found between the two "rabbit ears" is actually the UHF part of the antenna .. it can be rotated for UHF channels while the big ears are aimed and adjusted for VHF .. antennaweb.org will tell you which is UHF and VHF ..
Dec 28, 2009 | Televison & Video
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Digital to Analog Change Over
you are fine. if you do not get a pic or sound it could be that the rabbit ears you are using are not compatable with your box. you may need a diff. type of rabbit ears
Dec 30, 2008 | Zenith C27A24T 27" TV
Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Apr 22, 2008 | Televison & Video
Sony rabbit ears
The "Horse Shoe Like Ends" on the leads are installed under the Screws marked ANTENNA and then the screws tightened. If No Screws then your Rabbit Ears do not hook directly to this TV. Is there a connector comming out of the back that is Threaded? If YES, then this is your antenna connector (R59) and will require an Adapter for the rabbit ears. Available at Radio Shack.
Feb 04, 2008 | Proton MM2701VT 27" TV
Proscan TV Instruction Need
you wont be able to the high with rabbit ears antenna you will catch the low free channel.you need the cable to get the high channel.so it is est to connect back your cable good luck
May 06, 2007 | Proscan PS32600 32" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
