Question about Microwave Ovens
My oven will not heat up, but my broiler still works
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 31, 2010
GE Spacesaver JVM1660WB turntable does not rotate?
My range works and oven lights? Does this mean that the problem is the Relay or the thermostat? The heating elements for the broiler/oven look fine and so do the connections?
Aug 16, 2013 | Amana Radarange Microwave Oven
Electric range with es 100/105 electric oven, getting no heat to oven or broiler. how to fix this problem
My lights turn on Range works but the oven and broil doesn't. Is this the relay or the Thermostat??
Jul 16, 2011 | Frigidaire Microwave Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
heatman101
Jul 03, 2011 | Microwave Ovens
Tappan Oven 316246653. Preheating the Oven does not work. Bottom Heating Coil (if thats what its called) is not working. The Broiler Coil at the Top does work. Is it the bottom coil that needs replaced...
Usually when the element fails to heat up, It means its usually broke, cracked, or where they plug in gets brittle and breaks. Your best bet is to replace the bottom element.
May 23, 2011 | Microwave Ovens
While pre heating oven, heard a sort of explosion. The bake element was definitely broken. A new one was purchased, installed, but it does not heat up. The broiler also does not work, but stove top does....
i have seen elements short out and cause the main board to fail. if eeverything else works you know you have proper power , so i would say the board is bad
May 12, 2011 | Microwave Ovens
Can not get this pilot lite lite in the broiler
heatman101
Apr 30, 2011 | Magic Chef Microwave Ovens
The bake element is not heating up. The lights and broiler is working. Please advise.
heatman101
Mar 27, 2011 | Microwave Ovens
The oven does not work Broiler and cooktop are fine.
heatman101
Nov 14, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
