Question about Cameras
Keystone regal k109, how to change bulb? - Cameras
1. Turn the projector OFF
2. Make sure the lamp housing is COLD.
3. Remove the two hex headed nuts on the top of the lamp housing.
4. Make sure the top of the lamp is COLD.
5. Use your thumb and press DOWN firmly on the top of the bulb,
6. Grasp the top of the lamp firmly with your thumb and one or two fingers and turn it counter-clockwise one quarter of a turn.
7. Lift the bulb 5-inch-long out of the socket and housing.
The bulb is available on Amazon.
Posted on Jun 05, 2013
How do you change light bulbs to LED
If they are not dimmable fixtures just buy the replacement bulbs for whatever fixture your working on in led.
Oct 10, 2015 | RVs
How do I correct a trapezoidal display?
This is called keystoning and there should be a setting on your projector that will compensate for this problem. Usually it will be called keystone adjustment or something like this.
Jun 07, 2015 | InFocus IN2104 Projector
Headlights wont come on after replacing bulbs, high beams work tho. What do i do? 2002 buick regal
sounds like headlight dimmer switch that switches between hi and low beams has failed
Mar 03, 2015 | 2002 Buick Regal
Projected image too small
Did you replace the lamp with the EXACT type that was in the projector prior to changing it? Sounds like there is difference in lamps.
Feb 26, 2014 | Epson ELPLP42 PowerLite 280 Lamp
Projectors
Look for a "keystone" option in the menus, or possibly even directly on the remote itself. You should be able to adjust this one way or the other to digitally square up the image at the cost of some resolution and smoothness. Mind that it might instead have auto-reset itself because you moved the projector around also, some of them have an auto sensing function but it never works very well, might as well turn it off and tweak it manually. Also be sure to zero the keystone and physically true it up as best you can using the extendible legs before using the digital keystone to finish the job if necessary.
And thanks for being the first question I've seen out of a run of about ten which was both presented in full and understandable English sentences, and wasn't just something that could instead have been entered directly into google to get an easy answer... :-)
Jan 29, 2014 | Toshiba TDP-T45U DLP Projector
I have just replace the bulb and it works fine but in the lower corner of screen there is a message to replace bulb how do i clear this out ?
if I remember right, hold the 2 keystone buttons in and while you are holding them in, switch the projector on and continue holding the keystone in for 20-30 secs.
Jun 28, 2010 | InFocus ScreenPlay 5700 Multimedia...
Signal bulb on 2003 buick regal
To change front turn signal –
open the hood; look in back of headlight; two white clips; pull straight up, and then whole headlight comes out including turn signal; it is all one unit; remove rubber cover, then you take bulb out of unit. Mechanism that bulb fits in will need to be turned clockwise (looking from the front) and pulled to get it out of the larger unit holding all lights. Be sure and put rubber cover back on before re-inserting the two white clips.
Mar 16, 2009 | 2000 Buick LeSabre
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
How to Change the headlight bulbs for my 1992 Buick Regal
A torque bit screw driver are a philips screw driver should be all you need. JUST MAKE SURE NOT THE TOUCH THE BULB (new bulb) WITH YOUR FINGERS. Your body oil will make the bulb burn out quick!!!! Wear rubber gloves when installing the new bulb. f one is dim, you better change both sides. are the other side will also be dim.
Feb 06, 2009 | 1992 Buick Regal
Cameras Logo
378 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
