Question about Subaru Vehicle Parts & Accessories
I unlock my car and the horn goes off and the car will not start
    Sergeant:
  • 298 Answers
You will have to deactivate the security system first because the security is blocking the ignition or cutting the supply of fuel or the electrical system of the car. There is an error in the security settings of the car.
I will advice you reprogram the cars security settings to be able to use the car properly.
Posted on Dec 31, 2010
1999 Pontiac grand am horn goes off by itself and locks are locking and unlocking by themselves
Something going on with bcm. Note the diagram for the horn, one of the ground wires for control side of horn relay, goes to bcm. Probably part of security system. The other ground wire goes to horn button.
The bcm also has control over door locks. I can't diagnose your bcm from here.
Nov 30, 2016 | 1999 Pontiac Grand Am
Horn goes off when it rains!!!
Check horn contacts for corrosion
Jun 13, 2008 | 1999 Ford F350 Regular Cab
Hello,same as Matt,first my horn didn't work,is it unplugged,then I plug the horn,does not function .unlocks remotely and then the alarm begins to function!unplug quickly..I am French.THANK YOU
posting to USA Forum with a French car.
ok, its a CRD diesel, common rail diesel. we have no books on it here, nor car. my guess near same car as our Liberty
does car drive ok? engine run ok, and all things on car work ok but your listed items?
So the alarm is failing.
So the doors unlock ok, with the key fob, but then the alarm goes off. Id say, it needs help. get car serviced, or at least scanned.
if both key fobs fail, (do you have both, if no OOPS) get it serviced.
so does engine start and run, after unplugging horn.
does it?
if not does it crank over,(start spin over engine>?"
if no , then battery is dead.
Jul 30, 2016 | 2006 Jeep Grand Cherokee
Antitheft system keep goes on so i can't start my vehicle
It is telling me to lock the doors with the key, this will arm the system, then you should be able to unlock the doors after about 3 seconds and this should disarm the system. Also, if it doesn''t try unlocking the passenger side door or the back glass with the key. Let me know you must wait at least 3 seconds before unlocking back glass or passenger door to disarm system once one door is unlocked without setting off alarm it is disabled. hope this helps
Aug 06, 2014 | 1998 Nissan Pathfinder
Antitheft system keep goes on I can't start vehicle
Use the remote to deactivate alarm or use key in the door lock to unlock the door. The problem you had is when you lock the door and the alarm activates it must see a disarm signal or else it thinks someone broke the window and used the switch to open the door.
Horn goes off everytime I unlock my car
on my car its on purpose , i had to reprogram it . to off
or the alarm messing up.
looks like yours is.
the FSM shows how to find which door sensor (etc) is messing up.
there are some tests. to do.
Jan 08, 2014 | 2000 Toyota Camry
My car battery got dead so I bought new battery and tried to replace the old one. As soon as I reconnected the terminals of the new battery the car started making panic horn noise. Its horn alarm goes on...
On some models you can disable the alarm after you connect the battery by locking and unlocking the driver door with the key.
I would disconnect the horn or pull the relay until you can get the alarm turned off.
Sep 25, 2013 | 1999 Toyota Corolla
Mazda mpv 2001 alarm stay on and it does not start the engine
if you do not have a remote to press unlock on put the key into the drivers door, turn to lock and then unlock, the horn should stop and the engine should start.
Oct 14, 2012 | Mazda MPV Cars & Trucks
Horn goes off by itself
Go to the Menu in your Jeep. There is a question that asks you if you want the horn to sound when you unlock/lock the doors. You need to hit the Step button so that there is a "N" instead of a "Y" and this should stop the horn from going off
Jun 14, 2009 | 2005 Jeep Grand Cherokee
My car horn goes off when i open or close my doors
close the doors, lock the car, unlock the TRUNK!
May 19, 2009 | 1997 Volkswagen Jetta
Vehicle Parts & Accessories Logo
331 people viewed this question
Top Subaru Vehicle Parts & Accessories Experts
Randy Ohler
Thomas Perkins
Thomas Perkins
Todd Arndt
Todd Arndt
Are you a Subaru Vehicle Part and Accessory Expert? Answer questions, earn points and help others
