Question about Dell Studio Xps 7100 Desktop Computer (AMD Athlon II X4 630 500GB4GB) (DXCWDS11)
I want to install a cd/dve ram drive in my computer and would like instructions.
    Guru:
  • Dell Master
  • 2,178 Answers
Posted on Dec 31, 2010
Testimonial: "Thanks so much for your help. I've added a cd/dvd hard drive before on another computer and I just wanted to have a refresher course. Thank you!!!"
Not booting from cd/dvs drive, hard drive.
go into the BIOS: depending on your computer has soon as you press the power button press either del, f1 or f2 it normally tells you at the bottom of the screen. once in the BIOS change the boot settings, at the moment it's probable set to boot from the harddrive first. so you have to change it to boot from the cd/dve first
Apr 18, 2017 | Hard Computers & Internet
Tip
Ram errors, OS install errors, BSOD
These can all be cause my corrupt ram to tell if your ram is corrupt download <br /><br />memtest from <a href="http://memtest86.com">memtest86.com</a> you want the bootable cd image file<br /><br />burn this file onto a cd and then boot your computer from cd either setting <br />cd drive as first boot device in BIOS or hitting f12 as computer boots and in the quick boot menu selecting the cd drive<br /><br />when the memtest program boots up start the memory test<br /><br />if the test fails the corresponding ram module will need to be replaced <br /><br />hopefully this helps<br />regards<br />djbr1ck<br />
on May 13, 2011 | Computers & Internet
Got a HP DV9700 laptop..running vista 32 bit vista home premium.. my pioneer DVE-k17B is not being recognized by the operating system..
Hi Mark,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If you take all of the above steps and the system still does not see the drive, chances are the drive needs to be replace.
Dec 29, 2010 | Pioneer DVR-107D DVD±RW Burner
When i try and play my cd games on my computer, it doesn't do anything, so basically it doesn't read the disc not only this it wont even come up with anything on my computer help me !!
Check the Game CD/DVD requirements. If your game CD is newer than your PC, your PC may not be fast enough or you may not have enough memory - RAM - to satisfy the newer RAM hungry games.
OR one of your RAM modules may have failed. Check System memory summary. If the summary says, ie, 128MB RAM, but you have 2 128MB RAM modules installed, 1 RAM module has failed.
OR your CD Drive may have dirty optics. Insert a CD cleaner disk, run it for several cycles to clean off the optics with the brushes on the data side of the cleaner CD.
Sep 12, 2010 | Compaq (120192-B21) CD-ROM Drive
Problem when downloading file says installer integrity check has failed. common causes include incomplete download and damaged media. cannot install files.
If you're reading the file from a CD-ROM, then either:
* the CD-ROM drive is reading incorrectly,
* the CD-ROM is scratched, and thus cannot be read 100% correctly,
* bad RAM in your computer, that "corrupts" the data being read from the disk into the RAM.
Replace the CD-ROM.
Replace the CD disk.
Download "MEMTEST86+", and run it, to test the RAM; replace, if necessary.
Mar 26, 2010 | Computers & Internet
My computer will not recognize any cd or dve
Run the Fixit utility in this link
http://support.microsoft.com/kb/314060
Oct 27, 2009 | Dell Inspiron 1521 Notebook
I have already a samsung cd rw plus dve rom but i lost the cd for install in my system
The CD/DVD rom should be plug 'n' play so no need for a install cd, just plug it in your pc and the pc should automatically recognize it.
Jul 20, 2009 | Samsung SpeedPlus DVD-Writer 20x, Black ...
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
Instructions on how to operate
I called the 1-800 number for SONY and they connected me with someone at NERO and they walked me through it. THANKS, Todd T
Nov 18, 2008 | Sony DRU840A DVD-RAM Burner
LG MODEL NUMBER GSA-H42N 18X SUPERMULTI DVD BURNER NOT ABLE TO WRITE ON SONY DVD-RW DISC
in window under my computer is your DVD writer shown as DVD-RAM drive, if not then re-instal the drivers for your DVD.
If its installed as DVD-RAM then right click the DVD-RAM icon in the my computer and choose properties, under the recording tab select enable recording, try burning a cd using the windows xp based roxio by sending your files to the DVD-ROM.
If it burn a CD this way then all you neec to do is use a different CD burning application software.
Oct 22, 2007 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Dell Studio Xps 7100 Desktop Computer (AMD Athlon II X4 630 500GB4GB) (DXCWDS11) Logo
62 people viewed this question
Alun Cox
