Question about Transmission & Drivetrain for Suzuki Aerio
We have a 2003 Suzuki Aerio AWD with auto transmission. The transmission seems to not shift into 3rd gear at highway speed, staying in second and revving high. Otherwise the car runs normally. Any suggestions would be appreciated?
  • 24 Answers
I'm not an expert with the Suzuki, but I have had lots of experience with transmissions. Chances are, one of your shift solenoids is bad and needs to be replaced. There's also a much smaller chance that the wire going to the solenoid has been pinched or broken.
Ultimately, the car will have to be connected to a professional-quality scantool and driven to confirm it. Then, the solenoids will have to be removed and tested. They are always either located on the valve body in the transmission pan, or they are attached to the top or side of the transmission as a "solenoid pack", where all of the solenoids are replaced as a unit.
Step one for you is just to make absolutely sure the fluid level is good and the fluid isn't burned or contaminated. It should be nice, clear, and pink. If it smells bad and looks more reddish brown than pink, or it's shiny with metal flakes in it, then something else is wrong.
Posted on Dec 31, 2010
Transmission not shifting into high gear since abs/4x4 code
answer to any 4l60e trouble ' GMT400 - The Ultimate 88-98 GM Truck ...
www.gmt400.com > Street and Track > Transmissions
Mar 5, 2011 - Before guessing at transmission problems, check the fluid level (car warmed up, ... that do not show up as PCM codes (like shift A&B solenoid failures, for example). ... 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for ...goes into 3rd gear: Reaction planetary is worn out due to high miles or ...
GMC Jimmy Transmission Problems - Edmunds
forums.edmunds.com > GMC > GMC Jimmy
Dec 20, 2013 - 1998 Jimmy After truck warms up shifts hard between 1st and 2nd gears. any ideas ... The ABS light stays on,the engine light stay on, the speedo doesn't work, .... I have a 1990 S15 4x4 Jimmy with a manual 5 speed transmission that went out. .... While driving it will only shift into 2nd gear and 3rd no overdrive. and usually ... Ford F-Series Transmission Problems - Edmunds
Dec 18, 2013
Buick Rendezvous Transmission and AWD Problems - Edmunds
Dec 18, 2013
Dodge Dakota Transmission Problems - Car Forums at Edmunds.com
Dec 18, 2013
Ford Transmission Problems - Edmunds
May 14, 1998
More results from forums.edmunds.com
Automatic Transmission May Not Shift Correctly at High ...
repairpal.com > Problems > Toyota > 4Runner
Feb 03, 2016 | Cars & Trucks
03 suzuki will shift in to all gears but won't move
oops didnt read how to tow that suzuki,oops.
how far you go , over 200 miles>?
is it an auto or stick?
flat towed??
dolly towed,?
towed from front or rear.?
we cant guess any of that and are all covered in the operators guide.
clear as a bell too.
towing cars , most will damage the rear transmission bearing.
because its dry when engine not running.
so the rules are very strict. due to that hard fact.
soon as you tow anything , thing, "rear bearings."
or if Fwd car, same on front.
most cars are not designed to be towed and some only short distances.
Jun 15, 2014 | 2000 Suzuki Aerio
03 suzuki aerio transmission will not engage forward or reverse
I need to know the following -- manual or auto trans, how far it was towed, what speed it was towed at, why was it towed in the first place???
Jun 15, 2014 | 2003 Suzuki Aerio
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    I am getting a p0717 code, when i am driving and have to stop the car if i try to take off on drive it wont move, i have to shift it to a lower gear for it to move.
    P0717 - Input/Turbine Speed Sensor Circuit No Signal.
    P0717 code means that the computer isn't getting any signal from the sensor. Either the sensor is dead or there's a circuit issue (bad wiring, etc).
    The computer wants to know if the transmission is working properly. So it reads the speed of the input shaft and compares it to the speed of the output shaft. It knows which gear you're in because it commanded the transmission to shift into that gear. So, with the input speed, the gear selection, and the output speed, the computer can calculate how efficiently the transmission is working. If the speed is off, it knows that something is slipping inside the transmission. It can then try to boost the fluid pressure to compensate. If that doesn't work, it sets a different trouble code.
    Hope helps (remember to rate and comment this answer).
    Dec 21, 2010 | 2003 Suzuki Aerio
    Wont shift into drive
    Have you changed the fluid & filter lately? Start there, much cheaper fix than anything else.
    Sep 28, 2009 | 2003 Chevrolet Tahoe
    Transmission shifts hard down from highway gear only (D>3rd)
    I had the same thing! It was a computer issue. It only cost me about $35.00.
    Dec 29, 2008 | 2002 Dodge Stratus
    Transmission wont shift into 3rd gear.
    I had this exact problem on my 2005 5.3L Suburban... It would shift into 1 and 2 and reverse, but not 3 and 4.
    I took it into a transmission shop, and he said the 3-4 shift solenoid was burned up. Wanted 1500 to fix it. Far from home, so I have to pay it.
    Nov 30, 2008 | 1999 GMC Suburban
    03 suzuki aerio automatic transmition won t shift into overdrive
    You have two temperature lights that come on when you start the car, one red and one blue. After the car is started the red light goes out and the blue one stays on. According to the manual, (and from my personal experience with my '03 SX), the car needs to warm up to a proper operational temperature. This temperature is reached once the blue temperature light turns off, (or within seconds afterwards). If you don't allow your car to warm up you will notice hard or long shifting, rough idle, and poor engine performance. Never drive your car if the light displays a constant red temperature light.
    If this solution does not work see a Transmission expert of take it to your local Suzuki Dealer.
    Nov 16, 2008 | 2003 Suzuki Aerio
    Transmission & Drivetrain for Suzuki Aerio Logo
    383 people viewed this question
    Top Suzuki Vehicle Parts & Accessories Experts
    gbob59
    George Agios
    George Agios
    Are you a Suzuki Vehicle Part and Accessory Expert? Answer questions, earn points and help others
