I have a Whirlpool Model# LSQ7030LQ0 washing machine. The washer is making a lot of noise and the agititator seems loose and is flopping around as it turns. If I grab on to the agitator I can stop it from turning until something catches and it spins out of my hands.
    Sergeant:
  • 287 Answers
This "MAY" be an easy fix,
I have seen the main bolt that fixes the agitator to the drive shaft come loose.
If you can imagine the agitator as a cone, the top point of the agitator is a cap that should pull or clip off. If so, using a long extention shaft and a socket set, you should be able to tighten up the bolt.
Good luck and post back results
Posted on Jul 08, 2008
Drum flopping around and making clunking noise
Almost certainty that the bearings are faulty, major problem usually no worth repair fault is caused by overloading the machine
Nov 23, 2013 | Whirlpool Duet 3.8 cu. ft. Front Load...
Where is the lint filter on Whirlpool Washer Model LSQ7030LQ0?
There is no lint filter on your unit. What kind of problem are you having?
Apr 25, 2012 | Whirlpool Washing Machines
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
GHW9250ML0 - belt off, pulley misalignment, bearing ok
no pulley should have that much clearance or movement....Something is seriously worn. Perform surgery and find out what failed.
you will have poor performance until you get this issue resolved and tighten the belt correctly.
Sep 25, 2009 | Washing Machines
I have a whirlpool duet washer that is making very
It sounds like basket support failure. How old is the machine? They usually **** at around 5 to 6 years. Unless you are going to fix it yourself or it's under extended warranty, junk it.
The repair requires a complete teardown of the washer. two to six hours labor depending on tech skill level.
Jun 12, 2009 | Whirlpool GHW9200L Front Load Washer
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
