The two usb ports on right side do not work - Computers & Internet
  • Jeffrey Groves
    Jeffrey Groves Dec 31, 2010
    Please provide the make and model number of the laptop.
  • Rommel Alilin
    Rommel Alilin Dec 31, 2010
    Make and model of the laptop?
  • 4,338 Answers
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Posted on Dec 31, 2010
My NV55c laptop usb ports on the right side suddenly have stopped working.
Motherboard issue.assuming all the drivers are properly installed. Not uncommon. Use the remainder and if necessary get an adapter to increase the number of ports you have.
Aug 21, 2016 | Gateway Computers & Internet
Why won't the right USB port recognize when I plug in my mouse?
Your USB ports on your computer are plug and play. If you have issues with your USB port, it is port related, driver related or device related. The following solutions will help you identify the problem to resolve your USB port issues.
To Identify a Working USB Port
Begin troubleshooting your USB ports by checking Device Manager to see if your USB ports or hubs are working properly.
  1. Click the Start button. ClickControl Panel.
  2. ClickSystem and Maintenance.
  3. ClickDevice Manager.
  4. Double-clickUniversal Serial Bus controllersand check to see if all your USB ports, hubs and controllers are functioning correctly. Any devices not functioning will have a yellow exclamation mark in front of them.
  5. If Device Manager shows any USB ports, hubs or controllers are not functioning, check for updated drivers.
To Update the USB Port Driver
An out-of-date BIOS driver can create issues with your system recognizing the USB port.
  • Watch a Video on Steps to Update Bios on Your Computer.
    1. When the update process is complete, your computer will restart again to load the operating system with the new driver version installed.
Sep 16, 2014 | Dell Inspiron Computers & Internet
Pavilion dv7-6c95dx usb question
According to your manual the 3.0 USB Ports are on the left side of the computer and they are backwards compatible with 2.0 and 1.0 usb devices.
The right side of your computer is 2.0 and backwards compatible with 1.0 usb devices. The fact that your devices won't work on the right side tells me that they are 3.0 devices and will only work on the left side.
Here's a link to your user manual. Look at the description of the left side and right side usb ports. It gave the speil about 3.0 for the ports on the left side.
http://h10032.www1.hp.com/ctg/Manual/c03092987.pdf
May 06, 2012 | Computers & Internet
I have 3 usb ports( two at the back and one on the
Check to see if something else will work on the side port. It may not necessarily be a dead port. Just something you should know too; I used to work for Wal-Mart in the electronics department and they had to recall all their firefly flash drives because they had a tendancy to malfunction. Try using it on a different computer, it might just be a dead flash drive. I hope this helps your problem and I hope your flash drive didn't have anything too important on it :x
Oct 15, 2009 | Computers & Internet
Why don't the usb ports work on the side of monitor
is there an extra cable, aside from the Power Cord, and the VGA Cable? if not, look on the back of the monitor, there should be a similar plug in like a USB printer would have, its kinda square. If there is, you just need a USB printer cable to make it work.
Oct 04, 2009 | HP Pavilion (PN153AAR) PC Desktop
Presario A900 A976TU USB Port Issues
It may be that you need to update your drivers
Start here
Microsoft's built in drivers may not be making best use of your hardware and causing the problem you describe.
The driver may be for the motherboard and not usb.
Either way it provided you with the opportunity to update other drivers too
Aug 24, 2009 | Compaq Computers & Internet
IBM Thinkpad T41 docking station USB ports
Try removing all the USB devices in Windows Device Manager with the laptop docked. To do this: Right-click My Computer, left click Manage. On the right side of the window, click Device Manager. On the right side, click the + sign next to USB Devices. Highlight each device under this heading and hit Delete on your keybaord to remove all the devices in order. Then right-click Computer at the top of the list and click Scan for Hardware Changes.
Hopefully Windows will re-detect your USB devices and get them back operational.
Hope this helps!
Jan 30, 2008 | IBM ThinkPad T41 Notebook
USB ports not working DV 1000
I just fixed this problem on my dv1000. The problem I found was apparently the USB ports on lower right and left side only mounted on the mobo with light soldering and no soldering on the other side of mobo. Due to heat I guessed, they came loose. I opened the mobo (using guide from a pdf file on the net, sorry i forgot the exact guide but you can ask uncle google).
I took the mobo out and resolder those two ports with plenty of solder from the top surface only of the mobo as I unable to access the other side. Now they work again like charm.
The top right USB is different beast. It is on different card along with S-Video port and apparently in permanent damage.
Dec 06, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
