Question about InFocus LP650 Projector Lamp
InFocus LP650 Projector - No Color of Red
Our projector (InFocus LP650) does not project the color of red, however, if the projector is tilted (at least 45 - 60 degrees upward) or aimed at the ceiling, then the red appears.
When you place the projector on a flat table or surface, then, the red disappears to black.
This is strange. Any ideas or assistance?
Thanks,
Alex Taft
Springfield, Illinois
  • Anonymous Jul 18, 2008
    InFocus LP650 Projector all buttons are not working
  • 74 Answers
Is this with a source? if it is try using another cable.
Posted on Aug 11, 2009
  • 82 Answers
Try a new cable
Posted on Jul 26, 2009
My infocus will not come on. the red light blinks. change the bulb but didn't do any good
check the colorwheel. if the colorwheel doesn't spin, the lamp won't light. if no fans come on either, replace the power supply.
Oct 25, 2009 | InFocus LP650 Projector Lamp
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
InFocus LP650 will not come on
First try a firmware upgrade. If that doesn't help, it seems it might be a power supply issue since you said the led comes on very light. I repair these power supplies. My ebay id is gtitubro
May 29, 2009 | InFocus LP650 Projector Lamp
Replaced bulb in infocus 777 and background is red not black
Its not the bulb. I have repaired a few of these with color issues. and its caused by short wires that nearly pull out of were there plugged in at. A big fail on the part of the manufacturer.
you have to open it up and check all the wire connectors. Even a plug thats slightly pulled out can cause issues.
Feb 12, 2009 | InFocus ScreenPlay 777 Multimedia...
Red color absent from projector picture
try to use another vga cable connector ther might be a cut on the red color signal try to move the connector form left to right until it gives you the red color if it does change your vga connector hope this help you on your problem thanks
Feb 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
Colors showing red on screen
Hi Stella,
There is a button on the projector called "Auto Image"
Most people don't realize it's even there.
Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
Note: this feature is nowhere in the menu(s)
Good Luck!
SagerTronics
Oct 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Color shift
Hi there
There is unfortunatelly no section in the Service Manual to explain this sort of procedure.
You'll have to move the LCD panels one by one - millimeter by millimeter.
Mar 29, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
That color is not listed because it is either Green or Red. There is no Blue, if you are getting Blue, you have something that is extremely unusual.
Feb 16, 2008 | InFocus LP650 Projector Lamp
Red Color
lcd panel failure or bad main board. either way, you'll have to send it in for repair.
Sep 24, 2007 | InFocus LP640 Multimedia Projector
InFocus LP650 Projector Lamp Logo
415 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
