Question about Kodak EasyShare CX7530 Digital Camera
When I try to transfer pix from camera to easy share collection on my computer, halfway through I get message that says, Transfer Interrupted, Reason: Catastrophic failure! This is "catastrophic"-ly annoying!! How can this be fixed?
  • 747 Answers
So many people use the camera and a USB cable to download their pictures to the camera software programing installed on the computer a lot of the times this just becomes a big problem. What you are experiencing is one or more corrupt files on the memory card. There is several reasons for this but that's now what you want to here right now. Okay to fix the problem right now if you are using a PC with Windows XP home or newer you can go into My Documents and create a file folder I generally use Year Month Date. Make sure the camera has sufficient power to do a download turn the camera off. Connect the USB cable to the computer and the camera. Make sure your camera software isn't going to auto start then turn on the camera. One of three things will happen, you see a Found new Device and then an icon appears on the desk top, or you need to go find it in preferences it's show as an external device like an external hard drive, printer, CD/DVD burner and maybe have a drive letter D,E,F or something. Once you see this you can open it see the thumbnails click once on one and then select all copy and then past the file in the new folder you just made. At that point you should be able to open the file see the thumbnails and scroll through them and see the corrupt files. Now before you disconnect the USB cable you must safely remove device or eject the drive. The camera being the drive. Each computer system and programing call the same action several different things but it boils down to shut the cable off before disconnecting it. once the cable is shut off disconnect from the computer and camera. At this point you need to format the memory card. It's this formatting that will clean the card and prevent the rotten Catastrophic pains in the Lower Unit (or where the body meets the saddle).
Where the problem stems from is deleting pictures on the camera take more pictures delete more pictures shoot more pictures and so on and every time you delete a picture on the camera it leaves a whole. Eventually you can't take any more pictures because the card is full of whole the camera can load to or down load because it runs into one of these corrupted wholes and the whole issue come to a grinding halt. Causing a catastrophic-ly annoying problem.
Format the memory card every time you download pictures Format the card in the camera it is going to be used in.
Going back to the new file you created, you should be able to open this file within your Kodak programing as in "open" then search through the "My Documents".
Okay that's for now but in the future what I'm suggesting you do is take the camera out of the equation and use an inexpensive card reader that hooks up to a USB port. You would then remove the memory card from the camera and insert it into the card reader. The computer will immediately recognize this as a mass storage device and you can download the pictures files the same way I explained above. (To a new folder in My Documents)
I know this is a lot to ingest, formatting is explained in your owners manual if you have lost the manual I'll attempt to find an online version but some times Kodak isn't to helpful.
I sincerely hope this has been a help and Have a Happy New Year
Posted on Dec 31, 2010
Easyshare c533 transfer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 11, 2013 | Cameras
I am attempting to transfer photos from my C713, but I can't power the camera on when it is plugged into the USB. I have changed the batteries and the camera will power on when the USB is disconnected...
Easy shares are set up so they won't respond when plugged in to usb. When you turn the camera on and then run the easyshare program and lastly connect the usb cable, then the pictures and video will transfer to the computer.
You can also take the SD card out of the camera and put it in your computer and transfer pictures that way as well.
Nov 10, 2010 | Kodak EasyShare C713 Digital Camera
My camera will not upload to my computer
Time to start using a card reader instead of the camera.
Jul 18, 2010 | Kodak EasyShare C613 Digital Camera
All of a sudden my Kodak Easyshare 530 will not transfer pictures to my computer, I have reinstalled software, still does not transfer. Can you help me?
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If you suspect it could be directly related to your software.
You need to follow the instructions:
  1. Uninstall Easy Share software:
  2. Select Start > Settings > Control Panel > Add / Remove Programs.
    For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
  3. Select Kodak Easy Share software.
  4. Select Remove (or select Change, and then select Remove).
  5. Run the Clear utility:
  6. Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
  7. Click the Download button, and then follow the on-screen prompts.
  8. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Jan 10, 2010 | Kodak EasyShare C315 Digital Camera
Kodak DX7630 camera - using Kodak easy share - photos won't transfer - message says they are already transfer
All digital camera put number on there files. Go to your windows search and search for your file that you transfer. The search will tell where it is located on your computer.
Dec 07, 2009 | Kodak EasyShare DX7630 Digital Camera
S8100 FUGI CAMERA I've tried to get my photos onto computer?
Yes you have change the settings of you camera in saving pix. It's not a problem. On you menu, try to change the setting of saving your pix to memory like that of a cell phone. Try it, it'll work
Sep 22, 2009 | Cameras
Kodak Easy Share program blocks transfer of photos with the same number, as used before, though I am using different album. Message: "Pictures are already in collection and not transferred again". How to...
You probably can't turn it off. Download the pics from one of the cameras to a folder you create on your desktop and if the numbers are the same, simply rename them.
Sep 01, 2009 | Kodak EASYSHARE M1063 Digital Camera
Can't transfer pictures to computer
First start easy share program, than turn on camera, then plug in to usb
Jul 01, 2009 | Kodak EasyShare C340 Digital Camera
I have a Kodak EasyShare C530 that I use all the time. Lately the camera won't connect to the computer to transfer pix. I just get the image the camera is facing-no black screen before the connection is...
Hi, Here are a couple things you can try to isolate the cause of this problem. Here goes: 1. See if the camera will connect and transfer properly on a different computer. If so, then the camera is fine. 2. Uninstall whatever software you are using to transfer pictures. If you have not installed any software, it is possible the OS is doing this for you. If you have WindowsXP or Vista, you do not need any software for basic transfer. If you are using the Kodak software that came with your camera, try uninstalling it and re-installing it. Hope these tips help.
May 21, 2008 | Cameras
Kodak EasyShare CX7530 Digital Camera Logo
101 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
