Question about V, Inc. Bosch 18V Litheon Impactor DrillDriver CLPK23 180
The chuck is stuck and the quick release on the drill is not working and I am not able to remove my chuck How can I remove the chuck from the drill?
How do you work the keyless chuck on the 6.5 amp 3/8" rear handle pro drill?
Most drills with the keyless chuck work this way. Put the drill into reverse. Grasp the chuck with your left hand, and then pull the switch slowly. This should release the chuck. If your drill has no reverse, then grasp the chuck again with your left hand and hold the drill with your right hand. Turn the chuck with your left hand quickly, this should release the drill as well.
Mar 17, 2011 | Craftsman Garden
Remove dewalt chuck that is stuck
down inside the chuck head itself is a allen head screw,, it has reverse threads on it. if you have already removed this screw and the chuck is still stuck then you will need to use a small gear/pulley puller to get it to release.
(( note: if you do not have access to a puller -- stop by you local Dewalt repair shop and I am sure that they will pull the chuck off with their puller at no charge to you )).
c...
Jan 05, 2011 | Dewalt 18 Volt Compact Drill Kit
HOW DO I PUT THE QUICK RELEASE CHUCK ON A BOSCH HAMMER 11236VS?
I don't know that drill in detail but in general chucks for this type of machine are removed by pulling back the plastic ring behind the chuck and pulling the chuck out. So hold the drill with the chuck facing away fron you and grip the plastic ring behind the chuck (nearest you). Pull this toward you and pull the chuck away from you. Replacing a chuck is the reverse.
Jan 04, 2011 | Bosch Drills
I have a drill bit stuck in my drill and I can not get it out of the chuck How can it be released from the chuck that I can change to an other drill bit.
By stuck do you mean that you can not release the chuck? if so then you can use 2 channel lock pliers to grip the chuck and the base to break it free. i have done the same on a keyed chuck and a keyless chuck .
Oct 03, 2010 | Garden
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
How do I remove a stuck bit from the chuck?
put the drill in a vice. then use the chuck key  and a hammer to release the bit.
 if necessary use wd40 spray to free up chuck.
Jan 24, 2010 | Black & Decker 18V Cordless Drill/Driver
My dc927 chuck is jammed fully open and won't move. How can I lossen it. Regards George
Something I would try:
George, look down the center of the chuck jaws with a bright light. It's going to be difficult to see, but there is an Allen head screw down in there.
Taking the screw out, will afford you the opportunity to remove the chuck from the drill. The drill should have a slightly tapered shaft, and the chuck has a tapered hole to match. It might be stuck on tight. Tap on the back side of the chuck, with a wooden block, and hammer.
(Yes, this may require a helper)
Tap on one side, then the other to try to remove the chuck evenly.
With the chuck off it may release pressure on the jaws. It may not.
In this case the chuck will have to be opened up, (Which will release pressure on the jaws), and the jaws reset.
Aug 22, 2009 | Dewalt 18 Volt Compact Drill Kit
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
How to Remove Bit from Dewalt Quick Connect Adapter DW0521
Hold the chuck by its sleeve, put the drill in reverse (make sure it's set at high torque if you used it in a drill/driver) and go full speed. That should release the bit.
Jan 04, 2009 | Dewalt DW0521 Quick Connect Impact Driver...
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
V, Inc. Bosch 18V Litheon Impactor  DrillDriver CLPK23 180 Logo
95 people viewed this question
Top V, Inc. Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a V, Inc. Home Fencing Expert? Answer questions, earn points and help others
