Question about IBM ThinkPad R40 2722 Notebook
Not finding my wireless card
Have installed a new 160gig hard drive in my R40 notebook and have installed windows vista , it is not finding my wireless card have tryed downloading the latest drivers from the ibm site , and still not finding card
  • 2,028 Answers
You don't have the right driver, finding the right wireless driver can be a pain. Open the panel on the bottom and get the make and model of the wireless card. Then go to Lenovo's support site and read what card each driver covers, find the driver for that specific card and install it. If it still doesn't work, go to and search for the driver by the wireless card make and model. At this point, if the card still isn't working, then you may need a new card.
Posted on Jul 08, 2008
Compaq presario cq61 319wm i formatted the hard drive and put vista on it when it originally came with windows 7 , i can not find the correct driver for network controller or adapter , right now i am...
Your notebook does not have compatible drivers for Windows Vista. It only supports Windows 7 (32 bit and 64 bit). It is highly advisable to just go back to Windows 7.
Compaq CQ61 - 319WM
BUT if you really want to download the specific driver for your wireless card, you can find it here:
Atheros ar5b95 drivers
I hope this helped you.
Oct 21, 2011 | Compaq Presario Notebook
Problem with HP Pavilion dv6767tx notebook (intel core2duo T5550 @ 1.83 GHz, 3 GB RAM, 250GB HDD) I Needed Drivers For WINDOWS 7. It had windows vista prior. Now i have installed windows 7 ultimate , 32...
there is alot of drivers contained in a PC i find it hard to believe that windows 7 cant find 1 driver for the entire PC any particular 1 you are missing? you may be able to install drive in compatibly to mode
your also not really stating your problem other than driver issue
I also see that HP does not have windows 7 support for this laptop
I have also read of people upgrading from vista to 7 successfully
maybe try upgrade instead of new install
Feb 05, 2011 | HP Pavilion dv6000z Notebook
How can i turn on wireless adapter on the IBM thinkpad R40 laptop.I can't see the wireless adapter switch.......the drivers are already installed successfully.Please HELP!!!!!!!!!!!
the r40 has no hardware switch. it has a software switch. you must first determine what type of wifi card if any is installed. most of the stock cards are intel or cisco and the ibm support site has the software used to control them. sometimes, thru the network connections, windows can take control if the drivers are installed
Sep 27, 2010 | IBM ThinkPad R40 Notebook
Repairing a thinkpad r40. Can't get the sound to play
Yellow question marks would normally indicate that the drivers aren't installed.
Apr 28, 2010 | IBM ThinkPad R40 2897 Notebook
I cant get a wireless connection on my IBM R40 using a Linksys G
I had the same problem with my R40 (2681) and a Linksys G router. The specs on IBM's/Lenovo's site indicate that the wireless card in the R40 only handles certain types of wireless encryption. The newer types (e.g. WPA) won't work on it and they are usually the standard on routers nowadays. My Linksys G router works fine with the R40 with WEP or with no encryption. Not ideal, but that's life with an old laptop.
Dec 14, 2009 | IBM ThinkPad T40 2373 Notebook
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Aug 17, 2009 | Computers & Internet
Lost wireless - Ibm thinkpad r40
haha worrying isnt it...
after reinstallation of windows no drivers for blutooth , wireless quite often modem and same vga,
windows by default does not install because need specific software ...(drivers)
what you need to do is first of all find out what wifi it is ; like wlan400 e.g.
you then need to download and install the driver for it .as soon as the driver is present windows will detect and install device,
look in device manager for devices with no drivers intalled.
same precedure for each device.
Jan 24, 2009 | IBM ThinkPad R40 Notebook
Thinkpad r40 - wireless disappeared
Go to the control panel, then System, then Hardware tab, then Device Manager. Then Network adapters - you should have two network adapters one LAN and one wireless.
If most likely have one, the LAN adapter and a yellow ? against a network adapter - this will be a wireless adapter (its not installed)
Check your BIOS and make sure the wireless card is enabled.
You need to download from the IBM/Lenove WEB site the wireless driver (there may be several types that is installed for your model laptop). Make sure you select the correct Windows version driver.
When you run the driver,it will uncompress and copy to your hard drive in C:\drivers. You can then install the driver from this directory. If it doesn't work then repeat with another driver, most likely one that works will be the Intel one.
IBM R40 2722 1802 Error Message
This is due to the fact that IBM laptops have a list of accepted devices, and the pci card is not recognised in the list. On IBM - Amilo, Mini PCI card slot is usually at the back of computer. Locate and remove Mini PCI wireless card, you will not have integrated wireless after this.
Other solution is to find the option to disable mini PCI in bios settings.
Here is how mini pci wireless card looks like:
May 28, 2008 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 2722 Notebook Logo
227 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
