Question about Toastmaster Breadmaker's Hearth 1193 Bread Maker
I am using a mix to make bread in the breadmaker. It says to order the water, mix, and yeast according to the manafacturers instructions. I can't find the book.
    Genius:
  • Toastmaster Master
  • 1,280 Answers
Unless you are using the time delay feature you can just dump all the ingredients in at the same time. Choose your program, loaf size, and crust color and push "start" and that's it.! Add the yeast last if you are worried about it.
Posted on Dec 31, 2010
The bread briefly rises, but when it is 'done' it has fallen and is dense and tough-- not light and airy.
Never open the lid while bread is proving. Your yeast could be getting stale, try an unopened packet. Are you putting the ingredients in in the correct order. yeast must not come into contact with salt or water before the mixing starts.
May 03, 2015 | Kitchen Appliances - Others
Order of adding ingredients to bread maker
Not sure what order your machine might use but normally the yeast goes in first thing or last.
The aim is to keep the yeast away from all liquids and fats till the mixing starts. It must stay dry.
Sep 18, 2011 | Morphy Richards 48280 FastBake Bread...
Bought a silvercrest breadmaker,used it twice,but the loaves rise and then fall when it starts to bake, I dont open the lid and I put the ingredients in, in the order it says in the instructions I also...
i have had a breadmaker for years and had the same problem. bread needs to go into a preheated oven, not one that heats up as it starts to bake your bread. i only let my breadmaker do the hard work (kneading), when it's done the final punch back, i put the dough in a loaf tin to rise, before putting i into a preheated oven. result a perfect lof
Sep 11, 2011 | Kitchen Appliances - Others
Every time I make a loaf of bread it overflows the pan and pushes the lid up. I have followed the recipe in the book that came with the machine. What am i doing wrong?
You're using a fast-acting type of yeast instead of the standard active dry yeast. It's a very common mistake made even more common by the erroneous bread machine recipe writers.
Here are the rules concerning bread machines and the yeasts they love the most:
Use standard active dry yeast for all your standard-rise bread recipes.
For the fast-bake white bread recipes use only fast-acting dry yeast.
Fast-bake type mode selections are available on most newer models and the custom recipes provided in their instruction manuals are the only ones you should use. You should never experiment with recipe ingredients and their portions when using the fast-bake mode on any breadmaker.
P.S. Always refrigerate your yeast with a close eye on the expiration date.
When using grocery-bought bread mixes always substitute the yeast packet provided with fresh active dry yeast. Tip: A packet (or "sachet") of standard active dry yeast contains 2-1/4 teaspoons.
Hope this helps.
Jun 22, 2011 | Black & Decker B2250 Bread Machine
In what order should you add ingredients containing water, sour cream, flour, soda, etc. and yeast? My last bread never mixed and was one big lump. I have had my machine for years and can't locate my...
As long as you start the bread right away and are not using the timer it doesn't make much difference.......as a general rule I always add the yeast last and then push "start"
Apr 03, 2011 | Regal Ware Kitchen Appliances - Others
Need to know the order to place ingrediants into machineregal bread
Hi...Liquids and salt and sugar (if used) first. Next comes the flour....and finally your instant yeast sits on top of the flour. Salt will kill the yeast so if you use yeast that you mix with the water (proofing) then put the salt on top of the flour. Yeast and salt should be separated untill kneeding. Hank
Sep 23, 2010 | Regal Ware Kitchen Appliances - Others
My bread does not rise properly. Is it possible\r...
If the machine is heating the element is working.
If it looks like bread dough then the paddle is mixing.
It's more than likely your ingredients. Old flour, old yeast, not enough flour, not enough yeast, water too hot or cold.
Check each ingredient to the recip as you put it in. Put them in in the order suggested by the recipe. The yeast should go in last and shouldn't have contact with the water until mixing starts.
May 17, 2010 | Kitchen Appliances - Others
What is the order of the ingredients : dry first then wet
I usually put wet first then dry. Just don't mix the salt and yeast at the same time. The salt will kill the yeast.
If using the timer cycle to make bread at a later time, put all wet ingredients and salt in first. Then the flour, then put the yeast on top of the flour so the yeast doesn't mix with the salt.
Hank
Sep 30, 2009 | Regal Ware GL2850 Bread Maker
Bread does not rise
  • Make sure it is good quality Strong White Flour (not plain flour)
  • The amount of water you use is very important. Use scales for accurate results - 1ML = 1G for water
  • Make sure the yeast is as per instructions regards type/quantity/quality.
  • Double check that you are running the correct program.
  • Always put the yeast in first, as you dont want the water in contact with water
Having failed that I would return the machine
Jan 13, 2009 | Panasonic SD-YD250 Bread Maker
Not rising and meally texture
Hello psaulina,
When I hear of bread not rising, I always suspect the yeast first.
You said you've used the hawaiian bread mix multiple times. From the same container? Or have you tried multiple different packages (hopefully from different production lots)?
Back in the day when my Mom was baking bread on a regular basis, she'd occasionally get a bad batch of yeast, and the bread would be the weight and consistency of fruitcake, but with somewhat less flavor. (We ate it anyway).
If your yeast is separate from the bread mix (don't know, you didn't specify), you need to first check the quality of your yeast. If the yeast is too old, or just bad, your bread won't rise.
To test the yeast, mix a sample in warm water (~105 deg. F) and add a little sugar. If the yeast is good, it should start forming bubbles. No bubbles, time to get new(er) yeast.
If your yeast checks-out, then you need to see if something in the machine's process is overheating the yeast too soon - - the yeast's fermentation process creates the carbon dioxide (CO2) bubbles that causes the bread to rise (sort of like inflating a balloon, if you like). If something is killing the yeast (e.g. too much heat too early in the process), it won't react and create the bubbles.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Good luck, and thanks in-advance for your rating,
Jon
Dec 26, 2008 | Breadman TR2200C Ultimate Bread Maker
Kitchen Appliances - Others Logo
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
