Question about Denon AVR 3808Ci Receiver
Denon AVR-3808CI only works in Pure Direct or Stereo Mode and only with a stereo RCA connector (Audio let and Audio right analog signal). There is no output with the HDMI input or Optical Input. It does not show the GUI or output video. Any help would be appreciated. Thanks in advance.
  • 33 Answers
SOURCE: Lost audio for no apparent reason
Try unplugging your HDMI cable from the AVR I would like to see if your AVR is trying to use HDMI out instead of the composite. Next try plugging each device directly into your television, this will isolate the issue and tell us for sure whether or not it's the AVR.
Posted on Jul 10, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
  • 119 Answers
SOURCE: HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
Posted on Feb 25, 2009
  • 11 Answers
SOURCE: No system configration display on AVR3300 since moving.
Make sure the two switches on the remote are all of the way to left most position before you try using the SYSTEM SETUP button - if the AVR is going into SETUP, the LCD display should be saying "SYSTEM SETUP". (I think that model does - most do).  also make sure that the Composite or S-Video on the TV's input 1 work from something else like a VCR, DVD player, ETC. rule out the TV and the cable first.
Posted on Apr 02, 2009
petraman7
  • 1175 Answers
SOURCE: Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Posted on Apr 11, 2009
Avr 2805 only works on direct mode
You have a problem with your DSP circuit. Unless you are good at reading schematics and using DVM's and soldering, then you need to take it to a servicer.
May 16, 2012 | Denon AVR-2805 Receiver
In cable / sat mode accidentally switched to analog in stereo. i have 5 surround sound and can not get any sound. how do i get out of analog and stereo - i have a denon avr 1911
Carefully examine the front panel indicators for status of switches you DON'T want active.
http://www.retrevo.com/support/Denon-AVR-1911-Receivers-manual/id/23695ci376/t/2/
Register and download it for free at retrevo.com
See Page 17 and consider how the digital audio is assigned (page 46).
Feb 13, 2011 | Denon AVR-1911 Receiver
How to install a audiosouse equalizer (eq 100) onto denon 3805 receiver, without a tape monitor thanks henry
Actually, you have several tape loops: CDR/Tape, VCR1 and VCR2. The bottom right part of Page 7 in the manual shows how to connect a Tape Deck (or any in/out processor).
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
I have a whole array of 2-channel analog processing electronics looped out of one Tape Loop on my AVR - via a dbx 400x Program Route Selector - for making tapes or CD-R Audio recordings and otherwise modifying the analog sound for various purposes.
Aug 12, 2010 | Denon AVR-3805 Receiver
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Denon avr 3805 2 zone configuration, I added optical sound from TIVO and now zone 2 is not working. I did the test of the speakers and they all work. I have configured the main for 5 channel stereo.
Zone 2 needs an analog input to work, if you pulled the analog from tivo, put it back on. Digital will not pass on zone 2. If your analog is still connected as well, go into your receivers settings for audio and select "auto" not "digital" Check the settings on tivo as well. make sure it's audio output is set to "auto" if available. If it's not, it's default is "auto" and will output simeltaneously on all outputs. Hope this helps. If you need more help, post a comment and I will help some more.
Jul 05, 2009 | Denon AVR 3808Ci Receiver
Its working only in direct & stereo mode
maybe you need to replace a fuse?
is it hooked up correctly
Apr 23, 2009 | Denon AVR-1508 Receiver
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
No sound other than from direct stereo or pure direct. Denon AVR 2808
You can try this reset precedure below, but it sounds like you may have a DSP board problem. This is a new model of Denon, it should still be under Denon's warranrty, it has a 2 year warranty. If this does not help, you need to take it in to be serviced. If it is not under warranty, you will not like the cost of the repair. A new DSP board usualy cost about $300 and then you must pay for the labor. It is not cheap. This reset procedure has been know to work some minor miracles, lets hope it works one for you.
1. Switch off the unit.
2. Hold the following STANDARD button and DSP SIMULATION
button, and switch on the unit.
3. Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
Note:��If step 3 does not work, start over from step 1.
�� All user settings will be lost and this factory setting
will be recovered when this initialization mode.
So make sure to memorize your setting for restoring
after the initialization.
Jul 12, 2008 | Audio Players & Recorders
Jul 10, 2008 | Denon AVR 2808Ci Receiver
Denon AVR 3808Ci Receiver Logo
139 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
