Question about Peugeot Swiss "Black Angel" Tungsten Crystal Row Watch for Women
Hoe to shorten watch band peugeot ceramic - Peugeot Swiss "Black Angel" Tungsten Crystal Row Watch for Women
  • 6,771 Answers
I would take it to the watch repair facility, they will size it up right on the spot and may not charge you.
Posted on Dec 31, 2010
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I have a swiss legend keramica and i cant ajust the bracelet
Most bracelet adjustments require a special tool that is only found in a jewelry store, or your watch can be shortened by the manufacturer. Many watches have pins that push out if you look on the back of the band there should be arrows the pins push in that direction if you have something small enough to fit it the hole, be very careful to put the pin back in the same way. Occasionally some watch bands are not pins they are screws and it can be very difficult to tell the difference between the two. If the watch band has a screw it requires a very small screwdriver and you must be careful NOT to strip the screwhead! You can also shorten some watches by just moving the pin in the band buckle if you have a small tool you should be able to do this yourself, BUT wear glasses because pins will spring out, keep pointed away from your face. Hope this helps!
Sep 13, 2011 | Swiss Legend Karamica Beige Ceramic Watch...
How do you remove creamic links from a Chanel J12?
You have to have a tool small enough to push out the links, usually there are arrows showing which way to push the pin the arrows will be on the band. take a small hammer and gently tap on the tool to push the pin out. The ceramic is very strong so the hammer is safe, i have shortened many of these.
Aug 27, 2011 | Watches
I want to size my wife's Peugeot ceramic watch band to fit her small wrist. Any suggestions? Thanks.
I just got finish resizing the White Ceramic Peugeot watch I bought my wife. It's very simple to do
Feb 12, 2011 | Peugeot Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
How do I take out a couple links in the band of a 7056 White Peugeot watch. The pins are not spring loaded like most other watches. The band is plastic and there is only one pin per link. I don't know if...
Hi I just bought this watch for my wife's birthday and we had the same problem, it was too big. I googled and binged for a solution to shortening the band or to remove a link but no one had an answer. I go crazy with things like these and just decided to look at the watch band. First took out the pin for the latch so I can get a better look because that pin can be pressed down. On the inside of the band are arrows. Those arrows indicate which direction the pins can be pushed out. Just push the pin out with a tool, they will require a little pressure but they will give because one end of the pin is bigger than the other. Remove link and enjoy. Hope this helps someone else out there. Just a note this is only for the Peugot 7056 it has a white plastic band and I wouldn't recommend anyone try this with any other model as I don't know how those bands are designed.
Dec 30, 2010 | Peugeot Watches
I have a michael kors white ceramic watch and the band is too long? how do i remove links?
Ceramic links break VERY VERY Easily!!! Take your watch to a reputable watch repair shop and have them adjust your watch band! :-)
Jan 15, 2010 | Watches
I HAVE A PEUGEOT WATCH WITH METAL BAND. I CANNOT FIGURE OUT HOW TO TAKE OUT LINKS OR SET THE DATE
Today I brought a Ceramic Peugeot watch to a Certified Master Watch Maker who has 50 years of experience and he could not get the pins out to remove links, he stated they were too small and had no tools that size. I have found a service phone number for Peugeot Watches, I plan on calling them when they are open to see what they suggest, I am afraid I will have to send the watch to the service company for sizing.If interested the phone number is 888-223-0026
Dec 24, 2009 | Peugeot Watches
Peugeot Swiss "Black Angel" Tungsten Crystal Row Watch for Women Logo
216 people viewed this question
Top Peugeot Watches Experts
mike hayward
Vernon Taylor
Are you a Peugeot Watch Expert? Answer questions, earn points and help others
